chad pickens
what do set the t-stat at in your garage? summer and winter. In the spring and fall do you leave the doors open ? Any concerns with moister?
Humidity isn't an issue with a 10-mil poly moisture barrier and double foil-faced high-density closed-cell foam sheets under the slab and epoxy on top; the floor is always warm and dry.
