Garage trim to PVC
peterso2
Hello All!
I am looking to rip out the 2x6 wood that was used around the garage door as a frame and replace it with PVC so I never have to paint it. However I am not seeing PVC in this size. What should I do here? Need help! One is a single door and then the other door is a double. Also have to install the weather seal.
65ranchero
Danville, VT left NJ forever
Pictures?
2x6 is usually not for trimming
Is it the actual frame of the door?
If it is then it's a no go
but if it's just a trim piece then try this:
It will get pricey
it comes pretty wide 12" I think
You could double up the thickness and hide the seam with a cap of ripped down PVC
P
peterso2
I think you are right they just framed it and used that with a seal. Is that the proper way?
CraigStu
Blacksburg, Va
I did that at out last house w/ 7ft wide opening. There were actually three 2x6s somewhat like the OP's picture. I removed the 2x6 and replaced it w/ PVC that was about 1/2 inch thick. Did it mainly to get the extra 2 inches of width which was just enough to make hitting mirrors much less frequent.
mv213
Dallas, OR (the OTHER "Big D")
Look at that siding job..or lack there of. I bet theres quite a bit of rot that's hidden behind that siding. I bet the siding guy didnt have a brake.
Coil stock would be my vote too.
Yeah, don’t they usually use J-metal against the vertical wooden trim? I know they did on my old house when I had it sided in vinyl. Caulking is never a substitute for flashing.
Jayman17
Seattle, Wa
I was able to replace mine with a 1” thick piece of azek trim and still have it cover the garage door.
Jay
johnharris
TN
I would sand off the paint is some areas and inspect it. Especially the bottom which usually corrodes faster. If it doesn't appear to be corroded then just wrap it with aluminum. If it needs replacement I would use 2x6 SYP for the framing. For the trim I would wrap 1x6s in aluminum. PS wood will eat away the aluminum wrap over years. As mentioned earlier PVC trim does expand it the heat.
Skiff Builder
Southern NJ Coast
Hello All!
I used Versatrex pvc for 3 garage doors- both north and south facing. Fastened with Cortex screw/ plug system. Very happy with it. No gaps.
I do still paint it. Much nicer finish on cut edges and retards mildew stains. Supposedly good for 15 yrs.
It does come in 8/4 x 10. I used 1x6 over PT SYP 2x10 jambs. Built house ,so was able to lay it out for that.
If i was doing in just wood I'd use western res cedar- oil primed acrylic painted.
P
peterso2
Could I just use 1x6 PVC if it clears the door and use that? Any thoughts on trying to add a brick mold or leave it? And what about the seal to the siding do I need to get J channel flashing in there?
Thanks all!
Skooterj
Indiana
When the door is closed, how much of the door does the current 2x6 cover on each side? Standard PVC garage door trim, available at any hardware store is only 11/16th thick. And you have to do something about the front edge, usually covering it with brickmold. You could hide a 1x6 behind the PVC board if you need the thickness.
