Hi everyone, newer member here. I would like to add a utility sink to my new attached garage. It's a pretty easy task with the plumbing layout. My only issue is the drain. The closest spot to drain the sink would be into the laundry basin pump for my washer / basement utility sink. It then gets pumped to my septic. Has anyone ever seen or installed some type of filter in a 1.5" drain? I'm worried about any grit or debris from the garage sink going right into the laundry pump.
