Garage with no exit door
Blue2
I recently purchased a new home with an attached garage but no exit other than the garage door. There is no door to the house and no exit to the outside. I've never seen anything like this before.
The garage door is automatic so, if the motor ever breaks, there is no way in to the garage. I'm not even sure how I would get into the garage if the motor broke, but I assume it would cause some catastrophic damage!
This seems insane. I can't believe the house was built like this.
So this leaves me with two questions:
1. Short of building an exterior door (cost prohibitive plus 4-6 months waiting for a permit) Is the best idea to simply pull the red disconnect rope, unplug the motor, and use the door manually?
2. To make matters more complicated, the ceiling is very high so I cannot reach the garage door when it's open. I have no real way to pull it down. Is there a solution for this?
Thanks, everyone.
nadogail
Coronado, CA
Welcome to the forum. The more you can tell us about yourself; the better we can provide semi competent information and advice. Your location makes a difference because many issues are dealing with your local authorities.
Not all of us are in the same Climate zones.
I would bring this to the attention of the building inspector of the Authority having jurisdiction in your community.
billconner
Thousand Islands NYS
How often do you loose power that it would be a serious problem? I think I would plan on adding a door asap. You could add a small backup power supply. I see quite a few under $100 when I Google. Less than a door. Power goes out, open once and disconnect drive. Add a pull rope to close or stick with hook
Walkers
Cave Creek Az
If this is a new house, then simply push the button to close the door while you are inside, and unplug the unit. Then pull the release rope to open the door (make sure your car is outside), then raise the door, go outside, and close the door until it latches. Then call the builder and tell him your door doesn’t work. You will then find out how to get inside.
Then you can complain to the builder about the lack of a door. It is even better if ’you think your cat is in there’ and it is very hot.
Blue2
Thanks, all. This is not a new house.
Building a side exit door will be a very expensive and slow process and I don't really mind using the door manually. Is there any harm in doing this long-term with the motor disconnected? Is there an easy pull rope to install?
larry4406
Northern Virginia
They offer keys that mount in the door which releases the trolley allowing you to open the door from the outside in the event of loss of power.
One such device
Blue2
One such device
Yeah, the solution is that you attach a length of rope to the bottom of the door to give you something you can reach to pull it down.
Thank you both. I'll probably get both of these solutions.
CombatNinja
Oh, and pics of this house. No way it was built like that. The garage has to be a half-assed addition, probably unpermitted.
Blue2
Maybe I'm wrong, but don't building codes require at least 2 ways in and out?
I would think so. I'm really shocked that it's built like this.
And it was part of the original construction (not a half assed addition) and there are other homes in the neighborhood that seem to have this weird flaw. I have no idea how they got a certificate of occupancy.
Walkers
Cave Creek Az
Since it is not a new house, post a few pics inside and out. Adding a door is not a huge deal. If we know what you have we can probably guide you through adding a door. It would probably take you a day to do it, then paint the next day.
Neggy
how hard is it to put a door in, even if it is concrete block or other masonry construction?
My next question is IF you could put a door into the house (best case IMHO) are the floors different elevations?
In almost everyplace I've been, the garage floor has to be X many inches below the height of the house floor.
Windows? They can also be used to get out in a hurry, but you have to make sure they are not blocked on either side among other things
larry4406
Northern Virginia
Only reason I know of the outside garage door release I posted was I had a new build construction of a detached garage with zero other entrance. This was 10-15 years ago
nadogail
Coronado, CA
The OP wrote he recently purchased a new home; he did not indicate it was previously owned.
New is new, a resale is not "a new home".
Jagmandave
Overland Park, Ks.
Is this a troll? can't figure out how to reach the door when it's up? No location given or pics of said garage? No man door or window in a garage? I do know they build them like this in England, tho usually with side opening doors, not overheads.
65ranchero
Danville, VT left NJ forever
I kinda thought the same thing but you never know.
I did find it strange that a attached garage has no entry door unless the the house was built in the 1st part of the 20th century.
And also odd that the OP says its a automatic door.
How is it opened and closed when he want in? does it have a app on his phone or does he carry the remote every where he goes?
Jagmandave
Overland Park, Ks.
Good point, I guess his garage is just to store his car, unlike most folks in the US, for whom the garage is nothing but a huge storage closet! But he also could have a keypad.....I do. Not that it works most of the time.....
ericm
Southern Oregon
Long term I'd put in a man door. The garage attached to my house does not have one. To go in or out I have to go through the mud room of the house. It's a pain.
rayra
Escaped from Los Angeles
Another ludicrous and seemingly intractable problem posted by a new account.
It's EASY to cut in a door.
It is only as difficult or expensive as you make it.
And this really isn't a forum for folks who can't or won't DIY.
A pre-hung exterior door is ballpark $500 on the low end.
Maybe double that to include various interior and exterior re-work.
Jinks
Daytona Beach
No location, no pictures, unrealistic permit times (& not really needed), afraid of cost, etc. etc. etc. If the O.P. really wants help he'll become more reasonable, if not he'll go away......... :dunno:
Sumboodie
AK
billconner
Too many unknowns to know if adding a door is simple or not. No idea what is against that wall in house - bath, kitchen cabinets, etc. - and could be grouted masonry on edge of a steep drop off. Definitely not to code but doubt that would assure much than him being forced to add it. As far as new, we moved into a new home 2 years ago. It was 25 years old then, but new to us (especially considering previous home was built in 1904).
Key pad and battery back up. Too easy imho.
FMB4
Wife and I looked at a new build in '08 or so in ID. Garage had a door to the house and no other door, except the G door of course, leading to the exterior. We decided that we would have 2nd door installed that lead to the back yard/patio. Didn't buy it in the end, but that was our plan.
That said, not sure about the code time frame, but installing a door in previously framed wall is not a big deal to a contractor that knows what they're doing. Contractors do much more serious stuff all the time (like removing entire 'non load bearing' interior walls).
p00p
42.4974° N, 82.8964° W
you could install an UPS Backup for those power outage times.
Extend the pull release lanyard to your comfort heights.
Doing those two above should give you the ability to open the door to a point under an emergency.
Would it be easier to install a window that you can secure & unlock from inside & outside? It would also serve as a fire escape in a time of need.
slowtwitch73
Hellgate
It's not that hard even if you have no idea what you're doing. Plenty of info out there. I did my first one having had zero door experience. just did another one at new house. There's stuff to watch out for, but it ain't rocket science.
Showkey
"MEMBER EMERITUS"
Wausau WI
Similarly, it is asked, does a garage need a side door?
No, the IRC (International Residential Code) does not require a person door from a garage. A garage is not considered "habitable space" and is used for "vehicle storage", which is its primary intended use, so the vehicle door which is provided for that purpose is all that is required.
quickfarms
Southern California
Here in California that would be an over the counter, or email permit, using a standard plan unless there is something crazy about the construction
the only place I have seen a garage without a second means of egress is a garage constructed prior to WW2
if the garage is not permitted that could explain the timing.
the first thing I would do is to look at the construction to see if there was once a door or window that was removed
Viper98912
GA
I lived in an apartment complex years ago (and a relatively newer build too) where the first floor had some garages built into the building. They had no other access door other than the actual garage door itself. I wondered the same thing; if the door opener ever broke, I don't know how we'd get in short of trying to jimmy through the top seal. At the end of the day, it'd be the apartment complex's problem when they'd just need to break the door down :)
I'd definitely put in a man door into the house.
username2
If it's a one piece door, a person could sleaze a man door in the garage door lickety split I'll bet.
firebirdparts
Kingsport, TN
If you live somewhere that you'd need a 6 month permit period to buy a stupid door, it seems like you'd also have to lock the garage. Can you lock the garage? Have a key? I think it's pretty rare that people could find keys to their own garage doors, but of course that's not your fault.
My house was built that way also, with an attached garage that you had to access from outside. I thought it was pretty curious. I would never ask somebody else where to put a door in my own house, and honestly I would never tell you where to put a door. But I couldn't help answering since my house was the same way.
Killer95Stang
Our Southern CA 1961 home was not built with a man door in our attached 2 car garage. Since the back and partial side walls **** up against bedrooms, you cannot add one that leads into the house. Something about CO emissions and fumes will not all that to pass code. I did add one to face the side of the house, but that was only 3 years ago, so it went 50 + years without one.
