Garagedeck under Kwiklift?
BiggestMike
Austin, TX
I am getting the garage epoxied.
However I have a Kwiklift (most of you probably know what this is) and don't want to set it directly on the floor because I'm concerned that it'll gouge or scratch the epoxy.
What do you think about using Garagedeck under the feet of the Kwiklift? My thought is to use four squares of four tiles each under the feet.
lcrabtree
Bono Arkansas
Garage Deck will not hold up under a Kwiklift, under the feet or under the jack, unless you use something to spread the load. My 2400 pound car has made a warped mess under mine.
Lester
Prepman
Raleigh NC
Mike,
The carpet will be fine, but used plain carpet, not rubber back. You want it to breath and not stick to the floor. You also could use pieces of 1/4" smooth masonite board.
