Garages on hills, up, down or sides
uparms
Delaware, USA
Could anyone post some pictures or links to builds on this great site of ours of some builds on or into or atop or at the bottom of moderate hills.
I have a modes slope in the whole back yard and need ot get some ideas of the pros and cons.
Any help appreciated.
pattenp
Virginia - USA
What do you consider a moderate slope? My garage is 26' deep and the slab is 3+ feet below grade on the back and 1+ foot above grade on the front (door side). Maybe a 15 degree slope.
rsanter
visalia ca
a guy I knew that lived up in the hills had a nice setup
he used a friends tractor to dig into the hill for the garage so about half of the garage (diagnolly) was burried into the hill and the house was on top of that. the nice thing is that the back side of the house has its floor even with the land level (the side opposite the garage doors).
it worked well and was not much more expensive as he did a bunch of the work himself
bob
PurdueSD
Indiana
Hope these help!
More can be seen in the link in my signature...
chaingang
B'ville Ga
The left side of mine is about 4ft into the hill side. Block walls, it will get the tar, plastic, drain line, gravel and back fill this weekend. Have to let you know about leaks later. My house is built into the hill with a daylight basement but poured walls, no problems. If you do the prep and grade properly you shouldn't have any water/dampness issues. The gutters and downspouts are a key to this also.
PurdueSD
Indiana
I dont really see many cons other than extra cost. If done properly it will not leak. I used 2 coats of Dryloc on the block. Then laid black plastic footing tile in a bed of pea gravel around the back and sides. I have Commercial gutters and downspouts and made sure the ground sloped away from my shop. So far no signs of water inside.
5wndwcpe
Southeastern, PA
My garage (block) is about 5' below grade in the back. I used a high quality, rubberized foundation coating, 1" foam,acrylic coating, loose gravel for backfill w/ filter fabric, a footer drain and graded away from the building. As Purdue said, do it right and you won't have any problems.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
After sealing the foundation, lay some insulation against it before backfilling. Not only does it help insulate, it prevents any fill (gravel, stones, etc) from possibly taking some of the sealer off.
pattenp
Virginia - USA
Block or poured walls in the back? Black tar waterproofing? Leaks, dampness?
Brick and block. Block was parged with cement and then coated with tar. Drain pipe with a silt sock was placed down at footing then back filled with gravel. Gravel was then covered with silt cloth and then back filled with soil. I've had no issues with water leaks or dampness.
Alaskossie
My garage (under construction as we speak) is being built into a fairly steep hill (28% slope). The lower floor is a woodshop and "storage" (actually a guest bedroom and car-related library with a wood stove and a picture-window view of Anchorage, Mt. McKinley and the Alaska Range). A driveway will curve around and down to give access to the lower level (though no cars will be parked in that level.
The upper, main floor has two car doors for passenger cars, and a high door for trucks, where the 2-post lift will be. Then there is a mezzanine over the passenger-car side, for additional storage.
The east half of the main floor is built on grade, and the west half is on doubled trusses over the woodshop/storage area. Foundation wall construction is by a combination of block walls and 2X8's. Since the garage main floor is at the crest of a rise, we don't anticipate any drainage problems, but the block walls are waterproofed, insulated, and protected with a perforated perimeter drainpipe.
Since construction of my dream Garage Mahal is well along now, I'll post some details and photos separately.
TheShrine
Texas Hill Country
I have similar problems with the lack of flat land. My other problem is we're sitting on rock. Digging into the ground was not an option therefore we built on top and followed the slopes. On one corner it is 10" above grade. The opposing corner is 4'-8" above grade.
jkeyser14
(rural) Maryland
My garage is grade level in the front and 4' above grade in the back (4' drop in 22'). It's a 1950's home and they built it so that half of the garage floor is suspended over a crawl space. Horrible design if you ask me, the crawlspace is useless and smells like fox pee from a family of foxes that had lived there for years. On top of that, any of the machines I put in the garage reverberate like crazy on the floor. Sorry, no pictures at the moment.
DirtyWhiteBoy
Byrdstown,TN
Here are a few of mine. The foundation is aprox 8' in the back. Not ideal but it's where it needed to go. The foundation costs forced a reduction in the overall size of the shop, but I will make due, if I can ever get it finished:lol_hitti
musclecarfreak
Grain Valley MO
DSC02387.jpg Here is my shop on a fairly steep slope. It is 40x40 with a 40x20 deep basement. Makes for tons of storage....Lawn and landscape downstairs, toys upstairs.
U
uparms
Delaware, USA
Thanks to everyone, so far, that have posted advice or pictures.
All great examples of how others have built in greater hills then I have to deal with. I have 3 options of locations and will know more how much of my hills I will have to contend with after I present the plans to the neighborhood deeds people.
rgates
Maryland
Here you go. Hope this helps.
U
uparms
Delaware, USA
Like all the others this is a big help.
Please post a few more and explain to us what the lower portion is for. You can't move a car ver the top of that hill can you. Can't be for livestock.
rgates
Maryland
The lower portion is a horse stable, the upstairs is my shop. The hill is not a problem, the pictures are deceiving. We drive up and down it many times a day.
Mtriple
Twin Cities
Upper main garage (24x28) on the left and driveway down to lower garage on right.
Lower garage(24x28) directly under upper main garage. Both pics taken while building retaining wall to deal with the grade.
