garbage bench build part 2: this time with flat file cabinet
coldfoot_luke
Lexington SC
About a year ago I posted a bench build, made from craftsman tool checks and 6x4's scavenged from the scrap pile at work, completed with door from habitat rebuild: http://www.garagejournal.com/forum/showthread.php?t=222670
Ironically my garbage bench turned out a lot nicer than I thought and so it's been my staging and drawing bench, and I do my hammering/sawing/etc elsewhere. So, I thought I would be on the lookout for more salvageable stuff to make a second bench to beat up on.
My plant has been cleaning out storage areas, so I've gotten a flat file cabinet and two double-door cabinets before they were thrown away.
Here I've pulled out the drawers (eight total) from the drawing file cabinet to move it easier - walls must be about 3/16" thick, built like a tank. One of the double-door cabinets is behind it to the left.
Also scored plenty of 2x4's from uncrating a new production machine. Structurally the only new item is a 4x4 for the feet and legs. Started building a frame the other weekend:
Again, double-door cabinet in the background, doors removed convenience. The only wood that isn't salvaged is the 4x4 legs and feet.
The cabinets are 3/4" shorter than the file cabinet so I'm setting 3/4" plywood on top of the frame to raise the cabinets. The drawing file sits in between the plywood quite snugly, and I drilled four holes in all shared walls to bolt them together. After painting I'll join the cabinets to the frame with some bolt-on plates.
The overall length is roughly 106", depth is about 28". I'm going to make the top out of 2x10's and 2x6's, and they will rest directly on the cabinet tops. Each cabinet has four holes drilled into it, and the bottom side of the bench top will have threaded inserts to hold it all together.
Currently everything is painted, just waiting on the top, so I'll post some more progress pictures later on.
wrench409
Over here....
The 2x6 and 2x10 on my current bench are maddening! The stuff that falls in between the joints irks me to no end. I thought you were planning to use solid core doors?
I have a project in the works to use some my son gave me - two from an office building refurb. Both are not standard height so I'm re-planning my project to use the extra length.
C
coldfoot_luke
Lexington SC
Wrench - the doors were for my 1st workbench that I've already completed, they worked out great. Problem is the overall length for this is 106", longer than doors.
I have been thinking about what to do for the chamfered 2x10 edges, definitely don't want a gap or valley in between boards.
Captain - I am thinking along the same lines, have thin sacrificial board on top to make the surface flat without having to sand down boards too much, or fill in the gaps with a soft wood filler.
WxDude10
Chelmsford, MA
If you have access to a joiner/planer or a table saw, you can square the sides of the 2x6 and 2x10 and glue it together. That would get rid of the gaps.
C
coldfoot_luke
Lexington SC
Progress pictures...
I'm mostly happy with the paint on the file cabinet drawers, but the double doors have rougher texture... might re-do them all with flat black so it looks better.
