Jetsurgeon
Hi, I have an 8HP gas Emglo with a 17 Gal tank and a 4 cyl LU single stage pump, I want to convert it to electric, and looking around it looks like all I really need to do is get a 3HP Compressor Duty motor, remove the pilot valve and route a pipe to a differential pressure switch and wire the motor to that, and determine appropriate pulley size for the setup to get the desired RPM range on the pump (between 882 and 946 according to the MFR determining on 100 or 150 psi)...am I missing anything?? Thanks
