Gas dryer
2nrguy
Hoping i put this in the right place. Got a gas dryer that no longer wants to dry clothes, as in its not making any heat. i can run it for however long i set the timer for and whatever went in wet is still wet and cold. Hoping someone can give me a few ideas on what it could be, I know if I call someone to repair it its going to be a $200 call easy.
bubinga
do you feel any heat inside at all?
I had one one time, but it was electric, but the impeller fan that pulled the heat/air through the system was wallowed out, and would not turn.
It was on the other end of the motors shaft, from the drive belt.
Gotcha640
Houston TX
Another vote for solenoid valve, or possibly the ignitor.
In my case, I could take off the front bottom cover, and the valve was right there. I could hear and see the spark, but the valve never opened to get the gas going.
If you have no spark sound (tick tick tick, like a stove or grill or other electric start gas appliance) it could be the ignitor. The gas shouldn't flow if it doesn't fire up. My mom's worked if you lit the gas with a match, while we waited for the new ignitor to arrive.
Either part should be less than $25, I believe.
2nrguy
Thanks for the quick replies, now all i have to do is move all the other stuff out of the way so i can pull the dryer out to take it apart.
rlitman
Long Island
It could also have a hot surface ignitor. It'll be like a glow plug.
ddawg16
S. California
Open up the head unit on top. Most manuf will put a copy of the schematic in there.
You typically have two thermal switches. One is basically a t-stat...tells the gas solenoid to turn on and for the ign (glow plug) to light. The other is a high cut off. If the comb tube gets too hot, as in the blower not working, it shuts off the gas.
The dryer is usually real easy to open up. Lift the top up (it hinges) and you pull the front panel off. You can remove the drum...and if you manually close the door switch, you can start the dryer and watch the operation of the burner.
If you are using a voltmeter, with the dryer off, you should have a closed ckt all the way through the thermal switches.
mhm993
Dryers are easy. They inhale, burn gas to heat, and exhale.
Most likely a clogged vent duct. If the gas ignites for a moment before shutting, i always check for clogs first. Bad cage fan will mimic the symptoms of a clogged vent.
If nothing lights inside, look for a bad solenoid valve or igniter.
Sooner or later, all of these problems happen.
tasmith5
Mountain West
All good replies above. Just had the same thing happen with my dryer.
- check the vent duct
- check the thermisistor with a voltmeter for resistance. This is what when bad with mine.
I replaced the glow burner and the solenoids as well for good measure.
Wife says is works well now.
Cheers.
2nrguy
Thanks for the input. Got the parts ordered, just went with the idea of if one goes bad no telling how long the others are going to last. Kinda like ignition coil packs, you replace one then the old ones get jealous and want to be replaced also.
The FIB
chicagoland
Those ceramic ignitor's are very fragile and break easily, I found this out the hard way, be careful with it.
Garageguy65
Spokane WA
Don't touch the igniter element itself. Grease from your fingers will
render it a premature death, same as tubular halogen light bulbs.
Uncle Bob
I love modern technology...what ever happened to simple stuff ?
Yup.. Not on the dryer topic but this is why i have a spare ignitor for my furnace. Ignitor will die at the worst time. Dont want to be left in the cold.
2nrguy
Uncle Bob
So what your saying is I need a new pair of Mechanix gloves, because the old ones that are soaked in various vehicular fluids wouldnt be any good?
