Gas fitting?? Swivel 90??
NWOhioChevyGuy
Buckeye Hill (Morenci, MI)
So I have an LP gas rangetop installed and operational. But need a different fitting so my drawer/shelves clear the flex line better.
When tightened the standard 1/2” FNPT brass elbow points the wrong direction / towards the front of the cabinet.
What is the right part for a 1/2” FNPT swivel 90? If it exists it can be 1/2” FNPT x 1/2” flared so the flex line screws directly to the elbow.
I would guess they exist but not having much luck on the google machine.
Death Row Dave
Home
Would not use swivel 90* fitting . Need to check LPG approved or not . House burns down and it’s not approved you will not be on good terms with insurance adjuster . My thoughts are remove the fittings , 2 winds of “ John Crane “ yellow thread tape and tighten the fitting to your needed location . Reinstall the flex , pressurize and leak test . If leaking add another turn and retest . LPG is not a good thing to have a fuzz leak inside of a cabinet
fitter30
Peace Valley,mo
Rectorseal makes a thread sealant T-2 it has synthetic fibers in it used with yellow teflon tape should do what u want. Comes in a small tube. Put the fitting where u want it then check for leaks.
