SgtHawkUSMC
I've been looking at picking up a used garage heater. ~100k btu. Most everything I see on craigslist etc is natural gas. I've plumbed gas lines and worked on heating systems before, but I haven't messed around with converting a heater/heating system from nat gas to LP.
My plan is to buy a Modine style hanging heater for the garage. If I buy a nat gas one, I should be able to just buy the conversion kit for any of them right? Three or four new nozzles and spring? Once that's installed I can use my manometer to set is at 10 right? I'm not over simplifying this am I?
I'm also going to T into the tank after the first regulator. My tank is right behind my garage. I should just need to install the same kind of regulator set up that's on the house right?
The sky is falling and you can't work on your own stuff kind of guys don't need to respond please...
