Gas storage and pumping
Pntyrmvr
Headwaters of the GTA, Ontario
Hi,
Ma is turning 80 next month and lifting gas cans with more than a few gallons to fill her lawn Harley is becoming a chore.
I‘d like suggestions on a 120 volt gas caddy with about 10- 25 gallon capacity that would relieve Ma’s burden.
Even 12 volt that I step down with an inverter is okay.
Thanks team.
Keep Ma clipping.
Grogg
Vienna, Ontario, Canada
looking at your location, you can't be more than 30 minutes from a Princess Auto. I think you'd only need to hit 2-3 aisles to cobble together something that could work for what you describe.
I would suggest smaller cans and get mom to top up more frequently... less fuel involved is less weight, less risk, less to go bad sitting around each season...
unslow1
Illinois
I'm sure you could do that but mine just switched to a few 1 and 2 GL jugs. She still has to fill those jugs and move them to whatever garage or shed to store them.
MushCreek
Upstate South Carolina
I was looking for a similar solution for fueling my tractor. It's pretty tall, and holds at least 15 gallons. Balancing a 5 gallon jug at head height is not my idea of fun. I wanted to get a transfer tank to put in the back of my truck, along with a pump. There are plenty of them out there, but most of them are NOT rated for gasoline. If I recall, I found them to be too expensive, and I didn't pursue it.
u2slow
BC
I've got a 14 gal 'jerry can' with wheels and petcock/hose at the bottom. I roll it up on the 3' tall porch, and gravity fill anything I roll up next to the porch.
redmondjp
Redmond, WA
So is the gas caddy going to remain in one place? I've got a 14-gallon plastic one, and I only used it for one season because it is so difficult to move around. I can't even lift it by myself when it is full.
Here is another idea but it is a little more expensive - one of the metal 30 gallon fuel caddies (many of them available online) that have a hand crank pump on it. I bought one used for a mechanic friend and the hand crank pump is very easy to use - the pump turns in both directions as well so you can reverse the direction of flow to **** the fuel out of the hose once you are done filling something.
Once filled (not required to completely fill it BTW) using portable 5-gallon fuel containers, this caddy would be very heavy so it would need to remain in one spot.
Getting a 120VAC electric pump that is rated for gasoline is going to cost you a lot of coin. Heck, even the 12VDC ones as used on transfer tanks in the back of farm pickup trucks go for a serious amount of money. This is why I am suggesting the hand crank pump option.
u2slow
BC
Probably the same one I have. It is heavy, but I don't mind - it's a relatively infrequent fill. I like having a reserve of fuel at home.
