gas stove install
that-guy
NoVA
this seemed like the only logical place to put this
I just bought a house built in the 50's that had a propane range in it from the 70's or 80's. so I took that out and replaced it, however the entire propane run is copper piping and I want to upgrade it. my last house (only 8 years old) has CSST all over since the entire house was run off of propane. so I have decided to use this
my question is, can I use CSST from the tank all the way to the stove? i know i can use it throughout the house, but what about from the house to the tank?
i keep on reading that i need to bond and ground the CSST, but how do you typically do this? TIA
bobbyu
Nebraska
I don't think you can use CSST outside. I have NG and it is steel pipe into the house then CSST the rest of the way. Not sure about bonding. I can not see anywhere they did that on mine.
T
that-guy
NoVA
I had also read that about not using it outside. I would like to get more information on what is acceptable for outside...
I found the clamp for grounding the CSST, so that is no longer a question
T
that-guy
NoVA
still unsure what to use outside at the tank to go into the basement. looking at what the original owner did, they used a single piece of copper tubing from the tank all the way to the stove (about 15' run)
T
that-guy
NoVA
okay, so black iron from the tank to just inside of the wall into the basement, then CSST from there to the stove???
T
that-guy
NoVA
why do you need to "upgrade "the existing copper?
because copper is no longer code in my area, and it makes serviceability a challenge when pulling the stove from the wall...causing the copper line to kink and possibly break
zmaxmotorsports
South of omaha
If you get a lightning strike near by it will go through the trac pipe/csst and burn pin holes in the grooves in the trac pipe,bonding it to the water service gives it an easier/safer path to ground.
T
that-guy
NoVA
do you not have a disconnectable flex from the wall to the cooker
no, whoever did the install did copper line from the tank all the way to the cooker. this is a 50's built house, and looking at the age of the stove, it was probably installed in the 80's
T
that-guy
NoVA
I know I need to bond it to something in the case of a lightening strike, just wasn't sure why you specifically said to the water source
brewchief
CSST cannot be run directly to the stove, it needs to be terminated either below the floor and brought up with a ****** or terminated at the floor/wall with a termination fitting, at that point a valve should be installed and then a listed flex connector used to connect to the appliance.
CSST looks the same as a flex connector but it is annealed differently and is not designed for repeated flexing.
