I too have a cricut, but what I have outsizes the machine.I have a crycut for that purpose.
VitonWhat material do you need the gasket made from?
Just curious: is this for a fully constrained gasket or one loaded just in compression? I ask because FKM compounds (there are several) tend to be creep sensitive in my experience. And, if you think these are fussy and expensive, step into my world of dealing with very large flouro-silicone gaskets (think $6k a sheet).Viton
Loaded only in compression.Just curious: is this for a fully constrained gasket or one loaded just in compression? I ask because FKM compounds (there are several) tend to be creep sensitive in my experience. And, if you think these are fussy and expensive, step into my world of dealing with very large flouro-silicone gaskets (think $6k a sheet).
What do you use that expensive gasket for?Just curious: is this for a fully constrained gasket or one loaded just in compression? I ask because FKM compounds (there are several) tend to be creep sensitive in my experience. And, if you think these are fussy and expensive, step into my world of dealing with very large flouro-silicone gaskets (think $6k a sheet).
Large power transformers. Just the bushings, turrets, access covers, etc. the main lids are HUGE and we often do custom extrusions for those. The corner splicing of such gaskets is ultra-critical as it can cost literally millions to take one out of service to fix an oil leak. Newer ones tend to have welded on lids for obvious reasons, but a lot of really high maintenance units (furnace transformers in steel mills for instance) mount the winding on the lid instead of the floor so still use gasketed top surfaces.What do you use that expensive gasket for?
InterestingLarge power transformers. Just the bushings, turrets, access covers, etc. the main lids are HUGE and we often do custom extrusions for those. The corner splicing of such gaskets is ultra-critical as it can cost literally millions to take one out of service to fix an oil leak. Newer ones tend to have welded on lids for obvious reasons, but a lot of really high maintenance units (furnace transformers in steel mills for instance) mount the winding on the lid instead of the floor so still use gasketed top surfaces.
Turrets (the boxes into which the bushings are mounted) can be large enough to need a 48 x 96" sheet to cut one from. At 6k a shot, you don't want to screw up the design, layout or cutting!!!! Also, only a couple of utilities would use Fluorosilicone - most have the sense to use Nitrile (NBR).
