Gasoline Compressor
Jeeper75
Dayton, Ohio
Hello everyone, I am looking at getting a gas powered compressor, something 20 or 30 gallon, but don't know what brands to look at. Puma, Rolair, Northstar? Not sure what brands to look at. Anyone have any suggestions or personally used one? Thanks
mshell56118
Elkhart, IN
I have a sppedaire from grainger and have had no problems at all. the other guys at work have the ingersall rand wheelbarrow style and like them alot, I have also heard good things about the hitachi and rigid,my suggestion is to look for one with either a briggs or honda engine though
Bobcat753
New Hampshire
Speedaire and Rolair are the best out there. Ingersoll Rand are OK but there is room for improvement with their compressors. What are you looking to do with the compressor? Have it on a service truck or do you do carpentry work?
J
Jeeper75
Dayton, Ohio
I do not have 220 in the garage and don't plan on running it since I still live at home, and plan on moving out within the next year. But it seems I always need air where there is no electric, so I end up filling it up in the garage and heading to the barn to do stuff. Would just come in handy at my place and friends places, that I always seem to get suckered into doing projects.
stonesfan68
Houston, TX
I work for an Ingersoll-Rand distributor. The Honda-powered Ingersoll-Rand compressors are very good units. We have little to no warranty issues with the machine.
CNGsaves
KS and OK
Emglo has wheelbarrow style compressor with the 2 long dual tanks. It's popular gas powered compressor for house building, etc.
gooblunar
We have Ir , champion and John deere. My favorite out the three are the Deere compressors. They are very strong and reliable. We have the 17 cfm 8 gallon compressors. They hold the preassure better for blowing equipment off , then our big gas powered 80 gallon compressor in our service trailer ( can't remember the brand) and our 80 gallon Kobalt I our shop.
Monkey Milk
Hawaii
I have 2, a speedaire and a quincy. Both 30 gal, the quincy is 10hp powered by briggs and the speedaire is 12.5hp powered by kholer. The speedaire is 28cfm and the quincy is 18cfm. I killed the kohler motor already and going to be doing a replacement with a honda 13hp which I got already. The speedaire was always more powerful but always gave me trouble, but the quincy never did I have any trouble at all.
I say if your going to buying a gas comp make sure you get a honda motor and a USA pump.
Farmall 1066
Suburban Rockford, NE
I've got a wheelbarrow Emglo, with a Honda, and an ancient Quincy with a Wisconsin.
Usually use the Emglo, as its way more portable. Neither have given me any problems beyond maintenance issues.
Provincial
Near Salem, OR
For short term and not heavy use of high consumption air tools, a single stage compressor will be adequate. It will not hold resale value as well as a two stage compressor, so if you plan on selling it when you get your own place, keep that in mind.
A two stage compressor will put out more air for the same horsepower (and fuel consumption) and because it can hold a higher pressure in the tank, will give you more reserve with a high-consumption tool. It will have better resale value, too. They cost more to buy, either new or used.
I have had excellent luck with the Honda engines on compressors. I have had good luck with Kohlers, too. Hondas are easier to start!
I had poor luck with a Coleman (rebranded Sanborn) two stage compressor. It was basically a good cast iron unit, but the hairsprings on the intake valves would break and it wouldn't pump up well. The broken pieces would go through the rest of the system and sometimes get stuck in the one-way valves further downstream. It was a constant headache.
I also had a consumer-grade Ingersoll 2-stage with an Italian-made pump that ran at high speed. It worked well, but blew out the head gasket every 4-5 years. They quit supporting parts, so I made my own gaskets from heavy-duty material and they held up better, but not forever.
A cast iron pump will hold up longer, but will be heavier if you don't need it to be portable. Modern aluminum pumps seem to hold up well in consumer level use.
One factor to consider on a gas-powered unit is the unloading system. There are two basic types. The first lets the engine run at a constant, full-power RPM and just unloads the compressor so it won't pump until needed. The second unloads the compressor and idles the engine down until it is needed again. The second system is much quieter and also seems more fuel efficient, especially for intermittent use. If you are not going to use the air again soon, it is best to shut down the compressor until you need it again. This is where electric start is nice!
mikegt4
sw ohio
I picked up this Honda powered 2 stage Emglo a couple of years ago. It puts out 15.5 cfm @ 175. It has a small 8 gallon tank but they come in 30 gal. as well. It will fill the tank from 0 to 175psi in about 30 seconds and easily runs my **** Blast cabinet. They are now sold as "Jenny" which also has top notch wheelbarrow compressors.
I got it from a duct cleaning company, an industry where they are very popular.
http://www.jennyproductsinc.com/
mikegt4
sw ohio
^ ^ ^ NICE !! That's lot of CFM in small package.
How much did you have to give for that ??
I think it was something around $350. The guy had it on CL for sometime with no takers. It was/is in great shape. He had bought out another duct cleaning company and this was excess inventory.
I had been looking for one but they are usually way over priced or abused/neglected. It was $2400 new. It's mobility has come in handy more than once and not having spend $ to upgrade my wiring to accommodate a 5hp electric motor paid for this one. I don't use air tools every day so the inconvenience of rolling it outside is not a problem. It is easy to roll around despite weighing almost 300#.
CNGsaves
KS and OK
^ ^ ^ Nice score for $350 on the wheelbarrow compressor. :thumbup:
That's a ready made "mobile business" if you blow out neighbor's sprinkler systems !! :D
