Gasoline, fuel pump, pressure tester
zendriver
Indiana
I’m suspecting maybe the imported fuel pump (likely the only choice )I replaced is putting out too much pressure, flooding the brand new carburetor.
Any suggestions for a reasonably priced pressure test kit?
Thanks
cannuck
Rural SK
You can usually (or at least you COULD) buy low pressure fuel gauges at any auto parts store. You then need a selection of plastic "T"s to suit the hose sizes, as well as chunks of hose to go to the carb side. If you carburetor doesn't use a slip on hose connection, you might have to set up a brass pipeT to take hose barb on gauge side and male and female fittings to go between carb and fuel line end. All of that is if you want to read pressure in line while running engine. I don't think anyone makes a "kit" as such, but maybe they do??? If you just want to test pump delivery pressure you just need to terminate the hose to the gauge with whatever fitting is on the pump discharge port.
rust in the eye
Chicagoland
Unlikely that the fuel pump is overwhelming the needle and seat but any cheapo pressure tester from HF ect. will do. Shouldn't be more than 8 psi.
Did you say new carburetor? A few years back I overhauled a carburetor for a friend's shop. His mechanic installed it and found it was flooding. My friend who had talked me up about working on carbs called me over to have a look. His mechanic apparently had had some unflattering things to say about my skills.
Turns out a tiny piece of rubber hose was caught in the needle and seat. Rather than bend a new steel line to replace the old mangled one the installer had cut the steel line where convenient and pushed some rubber hose over the cut(sharp) ends resulting in the stuck needle.
I'm wondering if you may have a similar situation.
Z
zendriver
Indiana
Always a possibility, but the fuel system is completely been cleaned or replace from the tank (new) on down and there’s only about 5 inches from the final fuel filter to the carburetor. I will check float
I have been reading accounts (presumably real ) about how imported tractor fuel pumps, fail, or overpressure right out of the box. They are now made in those countries, in factories, but looks like the only PPE they wear is sandals, but that is the world of replacement parts for 50 year old tractors.
I swapped out the 10 year old Chinese pump that was working good because the systems was plugged with rust and the fuel pump was like 25 bucks. As a goof I tore into it just to see what it look like which it was fine but may have damaged it. I was looking at a box of stuff and I found the original fuel pump. I might test and put it back in except it’s a pain in the *** to change.
Z
zendriver
Indiana
You used to be able to get a low pressure adjustable fuel pressure regulator with a mechanical gauge on it.
Good idea
I have been looking at pressure regulators that do have a gauge on them. Not hugely priced and if it is high pressure, I guess I could kill two birds with one stone.
