gear drive come along
Krr1967
Has anyone here seen a gear drive come along like this one ? , it doesn't have a brand on it that I can tell . just says PEC on one side and pat. pending PT-39 I'm guessing that it is several years old .I didn't know they made gear drive come alongs have seen many of the ratchet types just trying to figure out what company made this ? thanks Kevin
jeremy v
I have heard of PEC before and I have seen a couple winch-hoists that look similar to yours, but they are not common by any means. I think PEC stands for Process Engineering Corporation if I remember correctly. That's about all I know, I hope it helps.
K
Krr1967
I have looked online for the manufacturer of this but I haven't had much luck
jeremy v
http://www.ebay.com/itm/2000-LB-CAPACITY-PEC-PROCESS-ENGINE-H4557-WINCH-HOIST-RIGGING-I-11-00-/380800794667?pt=LH_DefaultDomain_0&hash=item58a97f002b
http://www.ebay.com/itm/PEC-PROCESS-ENGINE-CORP-2000-LB-CAPACITY-STRAP-HOIST-WINCH-H4557-I-11-00-/291042002776?pt=LH_DefaultDomain_0&hash=item43c3748758
http://www.ebay.com/itm/PEC-HOIST-WINCH-MODEL-NO-015-1500LBS-CAPACITY-USED-/360809030445?pt=LH_DefaultDomain_0&hash=item5401e4e32d
Here are 3 Ebay links I found for listings with your brand of hoist. The last one shows a sticker that says "Process Eng. Corp. Crystal Lake, Illinois". It appears from the other Ebay listings that my memory might have been off related to the name. I was thinking PEC was Process Engineering Corp. but the other Ebay listings all show Process Engine Corp.
lametec
There's a Process Engineering Corporation in Crystal Lake, Ill., so I'm guessing the ebay listings with engine are wrong. Not to mention Process Engine Corp. doesn't make sense.
Sa-vise
Hello Kevin !
I have acquired a PEC PROCESS ENG. CORP. MODEL NUMBER H-4001 that looks very similar to the one you have pictured. The paper type sticker has fallen off over the and I placed it somewhere to keep it safe. Now if I can just remember that safe place I might be able to shed a bit more light for you. Just today I had to figure out how to disassemble the unit to reinstall the cable that let go inside the spool. There is a small set screw in the end of the center shaft that goes thru the gear and housing and is on the opposite end of the gear driven end. Remove this set screw and in the set screw hole is a small pin. The set screw when turned clockwise pushes down on this pin which in turn pinched the cable to hold the cable in place. On the opposite end of the center axis shaft to remove the shaft from that end you must remove the outside snap ring then remove the square key that holds the gear and axis shaft in place thru the housing. Or remove the outside snap ring from the other end of the axis shaft to remove from that side of the housing. Quite a unique setup actually. Never saw this kind of setup before today !!! Well I hope that helped a little bit in case you have to replace or cut off any bad or frayed cable ends like I had to today. It was a learning curve !!!
Happy New Year ,
Scott
Sa-vise
Hey Kevin,
Scott again, if you do stumble across this post and by any chance have found anywhere to find replacement parts I would be very greatful to find out where if you'd like to share that valuable info !!!
Thank you in advance, Scott
