Gear wrench ratchet greasing?
SuzukiGS750EZ
So I got a 4 set of flex head gear wrench ratchets. Greased a 1/4", two 3/8 and the 1/2 with moly grease. They all worked well except the 1/2. It would bind. I figured out the grease was creating a suction between the teeth. What else can I use besides oil? It's got a thin, non visible layer of grease all the other ones work great.
John316
Anywhere, USA
I have been successful with a THIN coating of superlube, but mostly use air tool oil in mine.
MikeF2316
Thornhill, ON
I've always used wheel bearing grease in my ratchets.
rickhigginshtbr
Lower Bucks, PA
maybe wipe some out, lightly grease it more often? never had an issue with the castrol syn grease i've been using, but almost out and grabbed a tube of lucas red stuff.
Fedwrench
Valley of the sun
Your Gearwrench ratchets are at least 60 tooth, possibly 84 or 120xp. They don't like grease. Grease is for low tooth count ratchets like 30-36 teeth.
Use a thin oil such as marvel mystery oil, 3 in one oil, air tool oil, maybe engine assembly lube but, not grease.:thumbup:
Murphy4570
West Deptford NJ
Just start doing oil changes and engine jobs more often. Having a drain pan under the car full of oil means your rachets, sockets, screwdrivers, etc will all find their way into taking an oil bath!!!!!
Happened yesterday with me with a socket falling into a pan of nasty grungy coolant...
TwoInch
NW INDIANA
grease will work, if it is the proper grease, and you do not use too much.
i have 84t gearwrench ratchets in all sizes, and they all have superlube in them. you must use a light coating, or you will get the binding/reversing stuff happening.
you can use a regular oil and avoid the problem all together if you like. i prefer superlube in all my ratchets though because it doesnt run/seep out, ever. YMMV
regular wheel bearing grease is not likely to work in my opinion. its too tacky(most formulations). a NLGI-0 or NLGI-1 would be better choice if you can find some.
TwoInch
NW INDIANA
I just use air tool oil. The fine teeth dont do well with grease
air tool oil might work. i personally wouldnt go there, as most air tool oils are about 5wt oils, and 30 or 40wt oils drain out of these ratchets really quick as it is.
the lube does no good if its not in the ratchet.
KinzeMech
just like most any danaher(think craftsman RP) or apex design, with a snap ring.
I misunderstood. I thought you meant flex head gear wrenches. I see now that you mean flex head ratchets (by gearwrench).
I have always wondered how the gear wrenches (i.e. ratcheting wrenches) are assembled, and how they could possibly be disassembled. They have no fasteners of any kind on the ratchet end.
ev2mopar
woodbridge new jersey
I place a few drops of gun oil in the crevices of my ratchets, as well as my ratcheting wrenches. I really don't take them apart, mainly since they are always in use!
The light gun oil seems to seep into the tools finer parts, and I can hear an audible tone change so I know it's getting in there.
KinzeMech
For my ratchet wrenches, that I have no idea how to disassemble, I saturate them with as much of a penetrating oil as I can get in there. Then I spin them, wipe away what comes back out, and repeat several times. I always get fine black grit coming back out. I don't think it's a matter of mine needing lubrication so much as dirt infiltration needing washed back out. I work on ag machinery, sometimes very filthy dirty working conditions. I have even had ratchets as coarse as a common craftsman RP accumulate enough dirt inside the mechanism to need disassembly and cleaning (they will hold a lot of dirt!).
TwoInch
NW INDIANA
i have pondered these same things from time to time.... :headscrat
cheechi
Triad, NC
CLP, remoil or similar?
