ron in sc
Geared head drill press: What is advantage, if any.
I am looking at large heavy drill press,
When the drill grabs............gear drive will guarantee something else will break or spin the part being drilled.
6061 ta and 316 stainless steel mostly 1 1/4 for both. other stuctual steel . would like to use hole saws if possible at 3 1/2 inch and larger. smaller stuff too.
What about noise? Is one type quitter than the other?
No I am looking at grizzly and bailey
2K or less if possible.
For drilling large holes with a twist drill, I would use an older geared head radial drill. They can be had cheap.
I wouldn't even attempt using a hole saw of that size in anything of thickness. At that point a waterjet makes more sense.
BTW, I have had nothing but bad luck with Baleigh junk. For a couple grand you can find some real nice american iron.
The gears aren't the weak link, the drill bit is. I run a large radial drill daily. If you don't watch your feed rate you will break a drillyeah or not.
i've had it bend shanks on bits when they grab with larger bits like 7/8" and up.
never broke the gears, the motor OL or fuses are more likely to blow than the gears to break if it stops dead, after bending/breaking bits of course...
