kartracer55
- Joined
- Jun 21, 2005
- Messages
- 5,317
Well yesterday I was extremely pissed off at the quality, or lack there of, of gear box's box end wrenches.
I was in a tight spot and needed a bit socket, but a ratchet wouldn't fit. So, I slipped a 10mm gear wrench over the shank of the CRAFTSMAN bit, fit it in and proceeded to try and loosen the bolt and CRACK! I split the gear box wrenches NON-RATCHETING ring end right open, right down the broach, and bent the other side of the ring end open. You couldn't even tell I had a wrench on the craftsman bit. I put my bosses MAC long box end wrench on in the same way and loosened it just fine.
Several weeks ago, I broke a 14mm gearbox non-ratcheting ring end and it resembled this one after the break, however I was definitely using some force with that one, but afterall, isn't that what they are for?
Bottom line, if your going to make a LONG box end wrench, make sure it can actually handle the torque that is going to be applied to it. They would be great if they made the box ends stronger on them. Really good idea, but a FAIL on GW/Danaher's part. For $130+ for the set, I was expecting something a little better. Feels like We're paying for the name, not the quality and its a shame because the design is great.
Jim
Jim
