Gearwrench pass-thru sets
SuzukiGS750EZ
Thinking about picking up the 3 pass-thru sets as something I'll grab eng I need to go fix the odd thing at somebody's house so I don't have to grab my socket rack and separate ratchets. Muy question is how well do they fit into places on the provided extension? If using 1/4" sockets are they say line the size of 3/8, 1/2 or are they fairly thin like 1/4 stuff? I'm thinking a situation like a plastic cover on a lawn mower in a recess or something tucked into a corner where Normal 1/4 stuff shines.
ItsNemo
Canada
The socket's themselves are equal outer diameter. The extensions and everything else about them is thicker than normal stuff. I have the 3/8" stuff and the extensions are as thick as regular 3/4" drive extensions.
Ole Slewfoot
Freedom, CA
the extensions are short and there are no flex options, but my 73 piece set does pretty much anything on a small engine. Every gearwrench case i've had the latch and then usually the hinge has failed, but otherwise the sets are very convenient.
DadsTools
This.
However, IIRC, the Gearwrench comes with an adapter that can turn it into a regular ratchet for use with standard sockets and extensions. But that being the case, you'd only need a pass-thru set for a specific application, everything else is probably better with a standard set. So, I don't think I'd go out to a 1/4" drive-range repair job with only one of these.
potato
a good set like the gearwrench 1/4 set is how id go.check the hot deals section,there is a deal where you buy the 3/8 set and get the 1/4 set free.its about 105 plus tax
Eric29
Western NY
I've tried to use mine. It's very weak for automobile repair use. I thought I could use it to tighten some nuts on a rear Toyota strut. You had to access the top of the strut by pulling the rear seat out and the position for tightening the nuts with an open end was very awkward. The gearwrench wasn't up to the task. I thought I was going to strip the teeth on the ratchet, even though not much torque was required. This was a very disappointing purchase.
Same here except that I still have mine.
LXCam
I have both the 1/4 SAE and met sets and both ratchets took a dump in nothing flat and they weren't even abused. I can't speak for the larger sets but I sure wouldn't waste my money on the small ones.
ItsNemo
Canada
They're no substitute for a normal socket set IMO but they are super useful in a few special cases. They work great for those studs with allen heads in the end, so you can do the pass thru wrench on the nut and still get an allen socket into the stud. There's also been a few cases where I needed a deep socket but there wasn't enough clearance to get it in, so this also worked. Granted, both these can be done with a combo wrench or ratcheting combo wrench, but the pass thru offers a bit more torque due to the longer length of the handle and reversible flex ratchet is easier to use. I also have the gearwrench tap/die set and you can use the pass thru set to drive taps/dies.
Tallpilot
Orlando
I bought the 1/4 flex head set just in case. Haven't used it yet. I don't think I would buy the other drive size although I already have half of the 3/8 set with the serpentine belt tool and that I do recommend.
Mr Ratchet
I have the older Kolbalt (Vortex) sets with a locking flex head in 1/4" and 3/8". Both have worked well every time I use them. I do at times use them in place of a standard ratchet and socket and they work the same. The sockets are very low profile and tend to be slightly thinner than their square drive counter parts. I also have 3" and 6" extensions for both drives. The extensions for the 1/4" Vortex extensions are about the same size a 3/8" square drive extension. The 3/8" Vortex extensions are about the size of a 1/2" square drive extension. They allow you to get a socket deep in a hole with a long stud if you ever come across that situation. I have a shotgun stock that has the nut deep in a tube within the stock. The Vortex 15mm is slim enough and with an extension fits perfectly. Even my 1/4" square drive Armstrong socket is a tad too tight. I also have the adapters to change the 1/4" Vortex Ratchet into a 1/4" square drive and the 3/8" Vortex ratchet into both a 1/4" and 3/8" square drive. I also have an adapter to go from a 3/8" square drive into a 1/4" Vortex socket/extension and a 3/8" vortex into a 1/4" Vortex. My 1/4" Craftsman (Vortex) drive handle serves as my nut driver. With the hollow handle and a socket, there is 4 1/4" of stud clearance. The extension/s add more if needed. I also have the Vortex tap handle set in 1/4" and the belt tool. I just got the Vortex torx and hex set that can be used with the Vortex and square drive tools.
It's a very versatile and valuable set in some situations. What they are not good for is breaking rusty fasteners loose due to their thinner design.
M6erfan
'Merica!
Pretty much sums up GW in a nutshell. ****...
ItsNemo
Canada
Other than the one bad batch of 84t ratchets that they replaced no questions asked, I've never had a single gearwrench tool fail on me.
The pass thru stuff is not heavy duty, is not for everyday situations, but it sure has saved my **** a couple times where nothing else would work.
motorhead12
New York
I have the Craftsman version, and it mainly gets uses because it has a nice blow-molded case which I can carry to a house call or whatever. The tools themselves seem pretty chintzy, and the pass-thru feature is marginally useful, but they work so can't really complain.
wolf_from_wv
WV
I've used mine to tighten up the shock bolts on a Focus, mounting posts, and on potentiometer shafts. I always grab the socket rails to take with me, though...
Ole Slewfoot
Freedom, CA
I've tried to use mine. It's very weak for automobile repair use.... The gearwrench wasn't up to the task. I thought I was going to strip the teeth on the ratchet, even though not much torque was required. This was a very disappointing purchase.
How do you know it was weak if you didn't break it?
I broke my '1/4', and I really should send it in again.
And I need a 14 and 15 if anyone is pitching their useless set.
Chromdome35
I have the GW 1/4 and 3/8 pass through sets. I don't use them very often but when I do, it's the only tool that will do the job. However, that is pretty rare, as there isn't much a regular deep socket won't handle.
Steiger9
I seriously looked at pass-through ratchets for combine belt tensioners (which are very long all-thread's). Had trouble finding a set with 15/16" which is what most of the tensioners need. Ended up going for a GW ratching combo and an Armstrong old laminated style. Glad I did if the ratcheting mechanism on the pass-throughs is weak.
I STILL like the idea of pass throughs, especially because (as I recall) they're a lot shallower since they don't have the square drive taking up space. So they fill that specialty tool niche as well.
zorrox
Can anyone explain to me the advantage of pass through sockets over a ratcheting wrench set?
Parrothead
Earth
If you’re using the pass through extension, clearance.
I have a pass through set but use my flex head ratcheting wrenches for almost everything.
Eric29
Western NY
From the feel. It's why I stopped overtightening things after a few years of working on cars, small engines, etc. You do this enough years and you can feel when something is ready to give.
DadsTools
I'd think for one, there's the reason why back in the early days the individual sockets each having their own integrated handles gave way to drive tools with interchangeable sockets. Also gives you the versatility of different attachments and extensions. To some extent, it's the same reason why mechanics don't work with just end wrenches, but need socket sets too. A ratchet handle can give you more torque in the smaller sizes. You can reach into tighter places with extensions like up under a sink where there's no room to swing an end wrench.
But pass-thrus are to me a specialty tool that excel only in limited applications. For example, if I was taking a nut off a length of all-thread that has lots of residue from having been exposed to the elements and dinged from impacts, I'd probably reach for a pass-thru ratchet for more torque. Biggest use here was tightening the nuts on all those long carriage bolts used in the barn construction--less fatiguing and easier on the hand than a ratcheting box end.
The trade off is having to buy another socket set then making a spot to store it just for those rare jobs. For mechanical work on vehicles or other equipment and machinery, most mechanics get by just fine with deep-well socket sets and ratcheting end wrenches that they already own in such rare instances.
Ole Slewfoot
Freedom, CA
Aside from not using cheater bars, I'm merciless with mine. If it breaks, Gear wrench will replace it. It's broke less than I would have thought.
The wrench heads contain the ratcheting mechanism, so they can make the head too fat to fit.
Backspacing above obstructions for the handle.
Can't slip down past the nut you are trying to turn.
Works with extensions.
The drive knurl is a good size for fingertip turning.
Eric29
Western NY
Good to know. I’ll stop babying it.
zorrox
Yeah I guess you would get more clearance in certain situations. I'm just a DIY guy though, so I would think my flex head wrenches should have me covered.
Bacon Man
I work industrial and they are time savers when doing all-thread. Specially in the smaller sizes.
