SuzukiGS750EZ
- Joined
- Apr 26, 2012
- Messages
- 3,273
Having never used the pass-thru ratchet set they make, I was wondering if it was worth the buy for automotive use and what they excel at. I would probably get a 3/8 set.
What did you mean by this? It cant be both.
One area where the pass through ratchet will excel is to cage your brakes on the big rigs.
A lot better than using a crescent wrench on a broke down HET in Iraq.
The number of times you may need the pass thru feature I would think is few and you could always use a box end wrench instead so why bother. This idea is not new. They have been around for a long time and the reason they never catch on is because there are tools to do the same job already in your tool box.
I guess I should say I've never used a pass thru ratchet. Don't own one for the reasons explained.
This has been my thinking too. I found a deal on the set for 60$ so i was just wondering if anybody had any "jobs" in which the tool made it easier.
Funny we were just discussing these at work the other day. I did find a use for them when tightening a strut assembly and using the allen hold on the strut shaft. The nut was recessed so a normal ratchet wrench wouldnt work thebpass thru was just deep enough & still allowed you to access the allen key at the top. Its one of those tools you may never need until that one time.
Sent from my SM-N910P using Tapatalk
i have a set. never used it after 12 years owning it lol
What do you guys mean by wires passing through? Like an oxygen sensor?I've found enough uses for them to justify my purchase, but it's not overwhelming.
The thing that would render them useless for me is if the ratchet head didn't flex. I repair musical instruments and percussion equipment has a ton of odd angles, as well as a lot of the electronics I use, for which the 1/4 set has been a time saver.
I've also encountered a few sensors with wires out of the top like mentioned above. Pass thru is great if the wires have a second connection- if not, you have to leave the ratchet on the part forever ;-)
