Sasquatch912
The pump hasnt hardly been used over the years. Every so often we would use it. I drained the water out i could after I use it.
Every year i change the oil and plug on it even if the oil is ok.
I also pour out the old gas and put in the new gas.
The issue i am having is the pump wont produce no high pressure. Water will squirt out but again no pressure.
Took off the pump. Dont see much. One seal looks like it has damage but ill let you guys judge that if you dont mind.
The valve spring was rusty a little but its ok.
Here are the photos
Here are the photos
