D45
I was given a "Broken" Generac 01676-02 pressure washer
Briggs 6.5 HP OHV
Intek 206 CC
2700 PSI
Came with the wand, hose, and a 6 piece nozzle spray kit
I took the carb off and cleaned it...…...fresh gas and it fired right up
The PO said it leaked oil...….and once a water hose is hooked up, he was right
It appears as if the pump oil is leaking where the pump head bolts to the housing...……….I assume either a gasket or O-rings are shot?
The pressure washer seems brand new, after a quick wipe down with some simple green wipes.
Briggs 6.5 HP OHV
Intek 206 CC
2700 PSI
