Bradbilt
Well the structure of the building is almost up.
The next step would be utilities and floor.
I am planning on 3 zone radiant heat.
There will be one floor drain in the wash bay. I am thinking one of these 4" x 12' drains right up the middle of the bay.
My question is the floor thickness. Will 5", 4000lb, wire mesh, & Fiberglass be strong enough?
The HEAVIEST thing that I will ever put in the garage is a semi truck that weighs 16-18,000lbs It is 22' long and the weight is spread out on 10 tires.
I also plan on installing a 12-15k 2 post lift. They recommend a 6" floor. Can I get away with 2'x2'x 8" cubes where the lift will be?
I was pricing out 6" and
I had to sit down for the $20-22k quote. That blew my socks off for a 4800sq/ft
What about thermal breaks to operate the 3 zones? Would a piece of trex and some sill seal on either side be sufficient? There will be a wall build on each thermal break
Thanks for any and all responces
I had to sit down for the $20-22k quote. That blew my socks off for a 4800sq/ftWhat about thermal breaks to operate the 3 zones? Would a piece of trex and some sill seal on either side be sufficient? There will be a wall build on each thermal break
