General framing question
Backwaterdogs
Illinois
Hey all was hoping someone could help.
Putting a wood burner and as luck would have it, I have to right where a rafter is ( yes rafter not truss).
So to get my exhaust through, had to cut out about 10 inch of rafter
I just supported the rafter by coming straight down with 2x on to structure tied in with ceiling joists. Wasn't going to be possible to box this cut in across to the other rafters.
Hope this makes sense. Sound like a reasonable approach?
scottydosnntkno
From the description, technically it is against code.
However, one cut rafter, that has the vertical weight/droop supports as you described will work just fine. Your roof decking can’t span 3-4’, so by adding to the supports you take the droop factor out. The only negative is the slight increase to shear/spreading applied to the wall but one single rafter should not have any detrimental effects. The sheathing has enough shear factor to make it up
Loose Ctrl
Upstate SC
What Scotty said. I would have boxed the rafters in around the through hole under the roof sheathing before tying into the ceiling/roof joists. If it was an option, I would have used offsets to move the pipe around the rafters.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
If you cut a rafter, you really screwed up. Plain and simple. You should have researched what you were doing before you did it.
Backwaterdogs
Illinois
This was a exhaust for a wood burning stove.
It was put in as close to ext wall as possible thru a hip. Where it landed in the attic space would not all you angle 6 inch double wall. So was either that or move the where it would no longer be centered.
Will try to get or drawing what I did...maybe will need to do something
Here is sketch of what I got
dWtiXA
Backwaterdogs
Illinois
Looks like I may be unable to post a url.or image since I'm a new account...had another acct for years but had to create a new one for this thread.
If interested my sketch of what was done is below. Have to change the x to an h and paste in browser.
Xttps://ibb.co/dWtiXA
Backwaterdogs
Illinois
On the side I cut the rafter, its 20ft I think, with a 6x6 on each corner and 6x6 post in center and two 2x6 wall sections.
Backwaterdogs
Illinois
The roof section on this wall is hippest mentioned and roof over this room is all rafters.
Don't remember how many rafters, but I recall them being about 24 in o.c. way out close to the wall where I cut. So must be a good 8 plus rafters tied to main roof support at peak to this wall.
I would cut the very center one and then supported as I tried to sketch below. Didn't take pics...just did it.
dWtiXA
Jim_No_Garage
Millington NJ
Worst comes to worst you have to go back and frame it like a skylight opening.
Double up full size lumber between 2 uncut rafters to tie in the ends of the cut rafter.
Jim
wrenchguy
NW Indiana
theres always more than 1 acceptable way to fix anything. maybe install undermount sleepers up and down run of opening. sounds like ur working down close to the wall a minimum height issue. prolly holding the rafter from the joist will work.
Backwaterdogs
Illinois
Thanks for all the replies!
Yes I it is a hip roof and ideally I would have frame it in
Like a skylight, but without cut a much larger hole in roof or room ceiling( room ceiling is tongue and groove, not drywall)...it just didn't seem possible, tho I know that would have been best.
Yes was out close to wall and pretty tight from below.
Guess I was looking for confirmation was I did will suffice...or if I need to plan to go back in and frame a box. But this will require coming from roof....not undo able, but will likely wait until spring.
firebirdparts
Kingsport, TN
Ceiling joists are not particularly strong, and so you did the wrong thing, putting a pretty heavy point load onto the ceiling. However, it may be fine in practice. A lot of things often are. I asked about the hip because I was wondering why the joists were running the wrong way.
LS6 Tommy
Northern NJ
Admittedly, I don't know much about carpentry, but as Mark Donohue once said, "If it doesn't look right, it probably isn't". What you did doesn't look right...
Tommy
