Generator Disassembly
D45
NW INDIANA
How does the electrical generator motor come off of the gas powered engine?
I have a Craftsman 5600w with a 10hp Briggs......given to me
Generator motor is burned up. Briggs motor works great
I want to separate and remove the generator motor
PoorUB
Fargo, ND
There is a through bolt on the end of the generator shaft that runs into the crankshaft of the generator. The engine shaft is tapered. In your case, beings the generator does not work you can beat on the generator rotor and the shock should brake the taper lose.
Now the bad part. The engine shaft is tapered. Like this,
There is not much you can do with it unless you swap out the crankshaft, or remove it and have someone machine the end of the crankshaft straight.
I see there is someone on eBay selling adapters that slip over the shaft. No idea if they work or not, for instance, (No idea if this will fit your engine!!) https://www.ebay.com/itm/132083677591
Go to James Condon's YouTube channel. He shows a couple of different methods in various videos.
nadogail
Coronado, CA
You may find yourself asking ,"why would anyone build it this way"?
The answer is, "That was the cheapest and fastest way to get the job done".
jubilee
Colorado
I hang generator with the engine facing down. Rig safety chain or wire with slack so engine won’t hit floor when the two come apart.
Spray as much of shaft with 50/50 atf/acetone as possible.
Rap end of shaft with brass hammer ( or such) every now and then during day.
Usually second or third morning, when I come out to shop, they’re hanging separated.
redmondjp
Redmond, WA
Yes James Condon does show a few different methods, but to save the viewer several hours' worth of hunting, I'll give the cliff notes version of my favorite method:
Remove bolt holding generator rotor onto the motor crankshaft. Fill hole with liquid - James has used water, I would use ATF or any type of motor oil. Then thread in the bolt and use an impact gun to tighten it until the hydraulic pressure pops the rotor off of the crankshaft.
Ingenious if you ask me.
But I concur with the above poster with regards to the tapered crankshaft, which about 97.6% of all of those type generators have. You really can't do much with them unless you are a machinist or disassemble the engine and install a different crankshaft.
The bolt has to seal, so several wraps of plumber's Teflon tape are required.
PoorUB
Fargo, ND
If the end of the generator rotor is threaded I have also cut a round shaft that just fit through the rotor, and run a bolt against it to pop them lose.
I had a small engine shop for a few years and did many engine rebuilds or replacements on generators.
  • Like
Reactions: D45
kelpaso1
MEMBER EMERITUS
New Brunswick
Same trick is used to remove the clutch from an ATV crank.
Showkey
"MEMBER EMERITUS"
Wausau WI
There are several engineering reasons for the taper:
1. Clearance is zero between the rotor and crank, so rotor clearance to the stator can be controlled. A slip fit with set screws would be too sloppy. Taper can be almost zero runout.
2. Taper allows the rotor and crank to be a perfect alignment. precision ……..Same reason they use a taper chuck on drill press and lathe center.
3. Taper allows the crank and rotor assembly to be supported by three bearings.
4. Compact package compared to belts or drive coupling.
The taper fit is actually more costly to manufacture.
Metallitubby
ATL OTP North
This method is standard for one specific Honda generator. When I explained the procedure to technicians, they'd give me the "no waaaaaay" response. It's nothing new, but it definitely works.
D
D45
NW INDIANA
I wonder if the stator can be rewound , where it would be cost effective?
It's a nice generator but the stator smells like its burned
D
D45
NW INDIANA
Craftsman 580.325610
5600w / 8000w with a 10hp Briggs
Generator stator​
Part #191042AGS
The manufacturer no longer makes this part, and there's no substitute part
PoorUB
Fargo, ND
Probably why you got it!
Have at it, knock it apart and toss the generator head and use the engine for something else.
D
D45
NW INDIANA
I tapped the end for a bolt and added a solid steel bar inside
Ran the bolt down and it won't pop off
D
D45
NW INDIANA
I'm going to pull the spark plugs and insert some rope, to keep the crank from rotating
Noltz
Ontario, Canada
That's surprising. In school we're taught a similar method as a automotive tech to get pilot bearings out of crankshafts. Pack them with grease, find a bolt the same size as your pilot nose and use it as a punch. Drive it in and the grease transfers the impact force to the back of the bearing - which pops them out.
PoorUB
Fargo, ND
Take a BFH and beat on the rotor. It is junk already, you won't hurt anything else. Put a wood block under it to support it.
It is crude, but effective.
  • Like
Reactions: D45
Metallitubby
ATL OTP North
That's surprising.
You've got to remember that our Power Equipment dealers vary wildly from great to guys in a chicken house. The training isn't exactly what I'd call "stellar" for the vast majority of most current power equipment servicing dealer (currently).
D
D45
NW INDIANA
It's removed
Looks like the shaft is 7/8" diameter
Wonder if I can cut the length down before the area were it starts to taper, and have room for a clutch
PoorUB
Fargo, ND
Can yuu buy a clutch for a 7/8" shaft?
I belive you will end up with a 1" clutch ad sleeve the shaft.
No shaft adapter available?
D
D45
NW INDIANA
I might just grind the shaft down to 3/4"
I just don't want to toss the engine, it starts and runs great
D
D45
NW INDIANA
Predator 301cc (8HP) shaft specs:
Diameter: 1.00" - 25.4 MM
Length: 3.48" - 88.50 MM
Predator 420cc (13HP) shaft specs:
So, both the 301cc and 4200cc engines have the same shaft specs
The Predator 6.5 HP (212cc) has a 3/4" diameter and 2.43" (61.70 MM)
I will look around and see if I can find a 7/8" tapered to straight adapter for somewhat cheap, even if that means the end product will be a 1" straight with keyway
PoorUB
Fargo, ND
Keep in mind with w 10HP engine you will want a 1" clutch. A 3/4" clutch will not be rated for the horse power and not hold up.
PoorUB
Fargo, ND
Keep in mind to get a key way cut and turn the shaft down you will need to remove the crankshaft from the engine.
nadogail
Coronado, CA
More than once I have tripped myself up by trying to "get by" with an under rated part because it was a few pennies cheaper. If you might need to return something you discover doesn't fit; better clarify that before spending your money.
