Northislander
Going to be starting the build of my generator shed at the cabin. This will be my third gen shed build. Each time I try to reduce the noise level a little more. So the current plan is:
Walls: 2 x 6 top and bottom plate with staggered 2 x 4 studs Roxul safe and sound insulation in walls 1/2" fir sheeting with 1-1/2" Comfort Board and 3/4" rainscreen then 3/4 cedar siding 1/2" res bar and 5/8ths drywall on the inside.
Roof: 2 x 6 Handframed rafters 2 layers Roxul safe and sound in attic
Slab: 4" concrete slab with 6" curbs on top filled with 4" of sand inside 12KW Kubota diesel gen with custom built skid will sit on sand. I have found the foundation is one of the weak points for sound transmission in past builds.
A Better muffler and insulated air intake and exhaust chases
Wondering if anyone on the Garage Journal has any other tips or suggestions for sound abatement.
On this property I can't move to far from the cabin without going up the hill which I think would broadcast the noise to my neighbors. So thinking of keeping it lower but closer to me.
