Generator through sub-panel
zhaddock
Kansas City
I was "gifted" a almost new 5000w generator this weekend. I know how to hook it into my panel but the issue lies in that I only have two available spaces in my main panel that I had planed to use for adding a sub in the garage. It would be very convenient if I could hook the generator in at the garage sub panel but I don't know if that would be kosher?
Hpozzuoli
Rhode Island
Technically you can't isolate the main breaker and gen breaker at the same time when doing it thru a sub panel so that's a no go. If you go the interlock route you can do it at the main panel. Very easy to do. I am not a transfer panel fan because I want everything live when the power goes and I go on generator.
****the interlock isn't approved everywhere.
nehog
Jaffrey, NH
... It would be very convenient if I could hook the generator in at the garage sub panel but I don't know if that would be kosher?
Not even remotely kosher. You must have an interlock or transfer switch which a sub-panel won't be able to do.
This is crucial for safe operation.
If you go the interlock route you MUST do it at the main panel. Very easy to do. I am not a transfer panel fan because I want everything live when the power goes and I go on generator.
Not the change I added.
This keeps coming up and I don't understand it. If the interlock is NEC and UL approved, how can a local code ban it ?
If it is a detached garage, park the generator in the garage and run a 8/4 extension cord from there to the generator inlet on the house.
