larry4406
We have endless discussions on generators - most centered on how and how not to connect them to the house. This is not the question here.
Anyone install watt meters to monitor the loads on the legs of their 240V generators?
I have been looking at the Reliance MB125. It uses current transformers (CT's) on Line 1 and Line 2 from the generator to monitor the load on each leg.
http://www.nooutage.com/mb125.htm
I have a 7500W Generac (13.5W surge).
This reviewer states that the CT's are not large enough to fit his generator wire (he used 2-2-2-4) so he had to swap out the CT's.
I was planning on using MHF (4-wire feed) for my setup so I am thinking I will likely have the same problem. I have not sized the wire yet but the total conduit path length will be somewhere in the range of 90-120' (portable generator will be outside on a pad, under an enclosure, 30' or so away from the house).
Am I better off just buying loose CT's sized to the wire I use and loose meters? Any thoughts on how to do this short of buying the Reliance MB125 and then likely having to replace the CT's?
