This is similar to what I used for my portable generator input... It is rated at 50A though...
It's similar in one sense, but VERY different in another. That is colloquially known as the "cali" connector. It is NOT a NEMA connector, and therefore complies with different standards and does not fit within the NEMA 'nomenclature'.
For NEMA, "L" designates locking, the first number designates the configuration (i.e. poles, voltage, neutral/no neutral), while the second number after the hyphen is the amperage. That doesn't translate over to CS plugs, which are CS####, followed by "C" for a connector.
Cali generator plugs are easily distinguished by the grounding on the shell, the protective shroud over the male cordset plugs and little prong on the female to guide it into the male connector (or are they female now...Only California would produce mutually transgendered plugs).
Both of these are 120/240 4 wire plugs (i.e. have neutral, ground, and two legs). But notice the key differences. Crucially, three prongs on cali vs four on the NEMA. ALL Cali plugs are three pronged, but the three wire cali plugs use one prong for grounding instead of the shell. Without getting into more details, it can get very confusing quickly, so just be sure to get the correct connector!
Cali 50a:
Nema 30a:
