Genie Door - install new
jicjoc
ON
Hi
I moved into a house with an old genie garage door. 1991 i think. Says
"genie deluxe 1/3 hp screwdrive" on the side. model 12a
I found the manual i think works..
It says the safeT beam should be connected to the STB module - but where is that? I cant seem to find it! I have 4 bolts above one light that seem to be for the wall switch and key pad but what is the stb?
Thank you
J
jicjoc
ON
The beams get connected on the terminal block on the back of the operator.
ok but which ones go where? I have the schematic and ive tried all 4 blocks and it didnt work. i tried 2 more that are on a separate module and still no good...
Hot Rod Grampa
Near Cooperstown New York
If you have the schematic the location is identified. Genie did not use 4 wire wall controls like sears or others did. They use 2 wires for wall and 2 wires for safety beams. But the wires go from sending unit to receiving unit. One has a green light the other is orange. The two wires from the opener go to the sending eye then to the receiving eye. Their system differs from the more common liftmaster.
