Geo-Radiant-Pole barn Question/challenge
I think I have a unique situation/opportunity.
Here are the stats:
Location=48022 (50 miles North of Detroit)
Pole barn=50x72x14
Walls=6" unfaced fiberglass insulation, steel exterior, plywood interior
Ceiling=12" cellulose (blown) insulation, plywood ceiling
Floor:
One 12'x12' insulated garage door
One insulated steel entry door
Six double pane windows
One 12 zone manifold
I have a backhoe and I'm not afraid of work. My goal is to augment a biomass boiler with a geothermal field. The barn is on a 10 acre field so there are no restrictions on digging. If I can keep the place at 40-50 degrees in the winter I'll be happy; if I can take 10-20 degrees off the inside temp in the summer as well, I'll be ecstatic.
My question is:
Here are the stats:
Pole barn=50x72x14
Floor:
- Plastic vapor barrier
- Foamular 250 - R-10 Styrofoam (under and around the edges)
- 3,500' 5/8" PEX on top of the foam
- 4" slab
My question is:
- How long of a horizontal geothermal field would I need with heavy clay soil and a high waterline?
- What size pipe?
- How big of a boiler?
