Several of my neighbours have geo thermal in their houses.... think of geothermal as a method that gets you 80% to your target heat.... the rest of the way is done through other heating methods (fuels like electricity, wood, propane, oil, natural gas, etc).
R
This is incorrect.
We have a Geothermal system in our home utilizing pex in slab floor heat and it provides 100% of the heating & cooling needs without any backup sources.
How old are your neighbors systems and how well are they insulated?
I doubt my statement is incorrect for every climate or local, and applies to the majority. Your local may be an exception in that with geothermal you get a perfect temperature.....
I am located in Ontario, Canada, 2 hours north of Ottawa. From below 0 F in winter to 90 F in summer is the range of temperature.
My one neighbor's house is built within 2 years.... It is a bungalow with walk out basement. Insulated concrete form bungalow top to bottom (R40 in the walls), underslab insulation, and min R 40 on the roof (possibly even R 60). Above the standard. He uses hot water tanks to raise the temperature to the final required temperature for heating. For cooling, there isn't much requirement other than a system to force the cooler energy through the house.
Are you stating that the ground temperature will somehow react and change to the temperature range of 0 F to 90 F???
Unless you live near a volcano, or hot springs (such as Iceland, or Radium Springs Alberta), it is HIGHLY unlikely the ground temperature is 72 F or above. And if it was the case, you would certainly be successful in heating, however, how would you use geothermal for cooling in that case?
Geothermal is based on a constant ground temperature, and the radioactive decay within the planet, and absorbed solar energy. The constant ground temperature of the earth is about 55 F anywhere from 6 to 10 feet down depending on local conditions.
In areas with wider ranges of air temperatures, you have to make up the difference either up or down unless you are happy with a temperature of 55 F.
I stand by my statement that for the vast majority of people in the world, Georthermal gets you from point A to point B. You will still need to expend some energy to get to point C (your desired building temperature)
R
Whoa jumpingryan, you seem to have a profound misunderstanding of what geothermal energy is.
Yes, you have a constant temp in the earth. You use heat pump technology to steal or give heat to the ground in order to heat or cool your home. So you can boil water by using a heat pump to extract geothermal energy from that 55 degree ground. You can also use geothermal for your primary heat source but you do need to use electricity to move and concentrate the available energy.
From what little research I have one, the combination of a geothermal heat pump and in floor radiant heat is not very popular. I think a lot of this is because multi-zone heat pump systems have not been popular (too expensive ?) until recently.
The newer high efficiency, multi-zone, inverter heat pumps do a good job of heating even in cold climates. Of course adding geothermal means you get maximum efficiency regardless of the ambient air temp.
Mitsubishi sells multi-zone heat pump systems and they have a heat exchanger for in floor radiant heat.
Didn't have time to read all of jumingryan's posts, but I did catch were he still thinks I'm using a backup source to make my system work.
I will say this again, I do not use a backup source.
Yes my Geo (WF Synergy 3d) has a backup heater inside of it, but I've disabled it (turned off the separate breakers) so it doesn't go on without my knowledge.
I have been running this system for 4 years this way and I have a Brultech energy monitoring system so I can clearly see how much power it's using and there is a clear distinction when the backup heaters kick on.
Edit: clearly after reading some more of your posts, you don't fully understand how a heat pump works.
My problem with the geothermal was that the payback time basically was when I had to buy a new system. I don't remember what the quote was but it was a pretty big number. How much does a basic system cost anyway these days?
Local energy guru used too small a loop.
INCORRECT !
Heat pumps can easily "extract" heat from a 55°F infinite source (the earth) and provide plenty of heat, even in the coldest environment. That heat can be transferred to air (for forced air heating) or to water (heat exchanger) to heat a floor or other mass that has water piped through it.
The International Ground Source Heat Pump Association
http://www.igshpa.okstate.edu/geothermal/faq.htm
"Q- Does this mean that in extremely cold climates additional heat sources are necessary?
A- All systems require an emergency back up. Heat pumps can provide all the heat necessary even in the coldest weather. An economic analysis by your contractor should dictate what portion of the heat should be provided by the heat pump and what portion by auxiliary means."
R
$30,000 CDN was the quote I got for a bungalow 1500 square feet retro-fit forced air setup. My house was built in the 90's. This didn't include outbuilding(s). This was for a horizontal run.
Vertical runs are generally much more expensive.
The damage done to the field area would have been minimal so that quote doesn't include an remediation of lawn/landscaping that might have to be done.
I didn't go further than the quote as my return on investment wasn't apparent compared to the time I will be living in the house.
R
Our decision was to try it for the first year and if it couldn't keep up install a propane stove or fireplace as the emergency backup
I agree and stated that auxilliary and backup are the same thing. Not sure where you read differently. Your mistake, JR, was that the backup/auxilliary power is what runs the compressor. It would appear from your last post that you have learned the difference between the power demands of the compressor and the optional auxilliary/backup demand.
You are mistaken again about power demands of the compressor. Just because the pump is powered through a 30 amp breaker you cannot conclude that it uses 30 amps at all, or constantly. That is silly. You know, I have a 200 amp breaker that feeds my house all the time. I suppose in JR's world, I am consuming 200 amps all the time at a cost of 172.80 per day.
Try to revise your assumptions without making up numbers. Still, a 20% input of power to get four times that much energy in return is a good deal. I would be happy to get a 400% return on my investment.
Yes, and what gets used to extract this heat? What "fuel" is used to "compress" this heat to get you the 20% of the way there? I would say it is a good bet to be electricity, likely a decent amount of it based on the size of the breakers needed to run the compressors of it (30 amps of 220 volt compressors)
READ MY ORIGINAL POST... this isn't about the process of extracting heat, and I made no claims about the process inside the unit, from using chemicals with low boiling points at sea level, to the conversion of a gas and a solid.
My point in my original post was the 20% energy you need to use to process the heat from the ground at the Unit. The ground gets you approximately 80% there, and is your chief source of savings. The remaining 20% is an energy consuming process that occurs inside the unit ...
100% CORRECT AGAIN ! (Except maybe the backup part.)This part of the process exists, and involves compressor's, pumps, heat exchangers, and if required a form of backup.
But if you do not understand the basic vapor-compression refrigeration cycle then how can you state that what other are doing is not efficient when they have the data to show that it is ?I never argued the process of extracting heat nor do I want to debate the boiling points of assorted chemicals and the storage of heat. Far too geeky for just about everyone here.
And now you have come to the crux of the discussion !Through our debate however, it is starting to appear that process of extracting heat uses alot more energy than people generally expect.
In addition, here is an interesting link on backups from people that likely know more than you about Geothermal..... They talk a bit about the backups that you said weren't needed:
I don't know if those numbers are accurate, but I sure would like to save 80% of my heating and cooling bill !In reality with geothermal you just save 80% , and pay 20% give or take as compared to your previous method of heating!!!
R
Wow, 30,000 dollars for a horizontal is really awful. Good thing that air source heat pumps are improving so much. Geothermal will be going away soon.
ABSOLUTELY 100% CORRECT !
I never stated the process isn't efficient at all, I just stated it isn't free as per my original post.
I am a BIG fan of geothermal, and strongly considered it for my house. I just couldn't get the payback in the amount of time I will be living in the house.
I am considering air source as something that can provide a better return on investment for the time spent enjoying it. My oil tank expires in 2016, and I will be re-purposing the house furnace to replace the garage one, and will be stick with a fairly new oil water heater to sell.
The COMPLETE geothermal process is highly efficient compared to other heating methods available. It's operating cost competes/is lower than operating with natural gas if you take away the install cost, and right now natural gas has nowhere to go but up... geothermal will always get a stable temperature from the ground.
My original post emphasised that operating cost still exists with geothermal.... the 20% I keep going back to.
As to the "backup/auxiliary debate", I am pretty much tired of it. Let a professional decide if you need something like an internal or external backup.....
R
OK, you have a total misunderstanding of how heat pumps, and how heat pumps referenced to a geothermal source, work.Yes, and what gets used to extract this heat? What "fuel" is used to "compress" this heat to get you the 20% of the way there? I would say it is a good bet to be electricity, likely a decent amount of it based on the size of the breakers needed to run the compressors of it (30 amps of 220 volt compressors)
Air source heat pumps, especially the multizone invereter heat pumps will give you a good return on your investment.I am considering air source as something that can provide a better return on investment for the time spent enjoying it.
R
How much can you save? My gas bill is approx $70 a month on a budget plan. ( heat, fireplace,drier and cooking) as far as I can tell the payback would be almost 40 years for me.How on earth could this be worth it??![]()
Geothermal is quickly becoming a dinosaur, there are better options now. With cheap current NG prices, you may never break even. Remember, the equipment has a life cycle as well.
Oh my god, you mean the price of natural gas will never rise and isn't subject to sometimes abrupt market price fluctuations???!?!?!?
Anyway, there's still nothing that rivals the efficiency of open loop geothermal and there's still nothing that comes even close to the cost predictability of geothermal. To me, I'd MUCH rather have a fixed cost for equipment that I can know and budget for up front than have a randomly changing payment to the utility company that's affected by the stupidity of the market.
Not to mention I can't get NG here, propane is an arm and a leg, and heating with electric is awfully expensive.
