geofoam anyone?
JimR1998
Southeastern PA
Does anyone have experience using geofoam in a small residential application?
I'm considering raising the floor height of a hollow block building about 3 feet. Conventional method is breaking up slab, fill and compact in lifts. The wall section, since it's hollow and unreinforced, needs to be taken down and rebuilt or something else done so it doesn't blow out with the weight of the fill and compaction.
geofoam, basically giant blocks of EPS foam, can be carried by hand and laid directly on the existing slab without concern of lateral forces on the wall. Concrete goes directly on top.
I may also be able to use the product for a driveway incline and not need to worry about retaining walls on the sides.
Contractor said he was a site where it was being used and might be something to look into. It runs about $50/yd, more expensive than fill but less labor to install and possibly cheaper in the long run.
If it exists, I figure someone here must have used it before!
willymakeit
Springfield Mo.
They did this on highway 65 at Branson Mo. Some of the fills were deep.
I would still want plenty of rebar. Make sure you have a way for water to get out. The void can fill and will float the foam if it gets in there before the pour. Did something similar to this on a project just finished and had this issue.
May not be a concern but I would worry about the foam compressing over time.
