Get a hook into it!
OccupantRJ
Eastern North Carolina
This is a simple tool I made years ago, but it has turned out to be one of the handiest ones I own, especially as I'm not getting any younger. It is a 34 inch hook with a T handle, made of 5/16" rod with a pipe handle, and can be used for a variety of things that you never thought of. It works great for removing jack stands from underneath a car, pulling loaded dollys, and makes moving that awkward table, cabinet or other low down heavy object in the shop easier. If you can hook a cabinet down low with it, it is much easier to move some things by pulling, rather than by pushing. Here I was using it yesterday to remove jack stands.
Craftman
Canada
it seems identical to what the milk delivery guys use to move around a stack of milk crate!
O
OccupantRJ
I first was exposed to these hooks years ago when I started working in manufacturing. I decided to make one for myself after using one to move something the first couple of days I was there. A real backsaver. We use them at work to steer long wooden crates on dollys, full of heavy screw machine stock, to maneuver down narrow aisles between storage racks.
Rolling_Thunder
Port Republic MD
Me like! Also getting tooo old to bend over more than I have to! Thanks for the idea!
Az Scooter
I nkow I used a hook like this to sling milk. I have also used it to push dents out of my truck, that someone else placed there.
O
OccupantRJ
That hook had been in my storage trailer for so long that I had forgotten about it. I just used that sucker to pull the mower deck sideways from underneath my riding mower. Yet again another use for it. I've already used it 5 or 6 times this weekend. It's kept stored on the upper bracket of my garage door track for easy access. :thumbup:
MScott
Eastern Ontario
If you have access to an old horse drawn rake, the kind that have a lot of curved "teeth across the back," you can make these hooks by simply hammering the tines straight, cutting them to the length you need and bending a hook in them. The top is a perfect handle. I have used these for years as a poker for moving wood around in a wood stove, but longer versions could be used as you have. These rakes are all over the place in farmers fields.
DrunkSmurf
NorCal
I've had similar type tools in the past myself and this reminds me I need to make one up...lol
I had one that I welded a second reversed direction hook on the opposite side. It came in handy as well. Worked great for fetching gallon paint cans off high shelves etc.
O
OccupantRJ
I thought about putting a dual direction end on mine also, to push things with, but just never got to it.
willy3486
Middle Tennessee
As I am getting older I think I need some type of tool to help me get off the ground. A lot of times I am on the ground working on something. Like today I changed out my brake rotors and pads. I need something help make it easier to get up. I think its more of a global warming thing. Global warming is causing gravity to make it harder to get up. Its similar to my old 66 pickup. The metal in it is shrinking and I think its global warming as well. I have had it since 1980 and it has shrunk because there is not as much room as there use to be in it. Seriously I think I need to put this on the list to make.
O
OccupantRJ
Laying down on a deflated air mattress, then inflating it when you want to get up will get the first 6 inches of getting up going for you, Willy. :thumbup:
brett09
Reminds me of something very similar my dad made. Its made up of 5/16 stainless rod with a welded T piece for a handle. We never used it around the shop or house though, it was always just for hoisting heavy fish into a boat. A gaff. Ha never would've thought to use it any other way.
