Get Attached; Threaded Fasteners, Hoisting Slings
Toolmaker51
Missouri
Kansas City, MO
Price
Varied items from $3.00 and quantities, to $21.00
I have a surplus in NEW (a) small threaded fasteners, (b) polyester hoisting slings. After enjoyable morning in the forum ranting on about swap meets [I posted remedies; slow to evolve, long benefits] whilst awaiting deliveries.
Then working in back,HGR_Euclid.jpg came up with these.
(JK, HGR occupies old GM plant, Euclid OH. Freakin' humongous!)
Certain there won't be duplicate opportunities here; I commence. Cross posted, sure at 2x prices. Those people aren't so kindred, likeable or aware.
#4 x 3/8" Sheet Metal Screws, Steel, Zinc Plated, Phillips Drive, Pan Head. 100 round clip, magazine, err 100 screws per box $3.00.
#6 x 3/4" Socket Head Cap Screws, Alloy, Black Oxide, Hex Drive, Flat Head. 100 per box, $6.00.
Can Flat Rate the boxes, seems costly; or flatten and send bagged in a mailer for a couple bucks. USA only. I'm Midwest, no shorter delivery path than that!
Hoisting Slings. Many of our A-frames are 1/2t or 1t chain fall. Little hooks don't fit everything, not everything has holes, stuff gets heavier daily!
[I like to write. You like to read?] New polyester endless slings 1" x 23-5/8", minimum breaking load (straight) of 4629 lbs. Tags in metric specifications, conversions noted in pictures. They can be configured for lifting, only one of common uses. Also exceptional connection for tie-downs. Where hooks don't fit well; on machinery, or such as motorcycle handle bars, ideal to avoid cables or scratches. With minimal care, will last years of use. Like any webbed product, padding of sharp edges, is the best insurance. Particulars? Specs? You Bet!
SLING MBL (Minimum Breaking Load) 2100 kg = 4629 lbs. SLING WIDTH 25mm = 1" in. SLING EFFECTIVE LENGTH 0.6m = 23-5/8" in. SLING CIRCULAR LENGTH 1.2m = 47-1/4" in.
W.L.L. 2100kg = 4629 lbs Vertical or Straight.
(factored into other configurations)
x 0.8 1680kg = 3703 lbs Choker
x 2.0 4200kg = 9259 lbs Basket
x 1.4 2940kg = 6481 lbs Slung in two points at 45° or less.
$7.00 each, $13.00 for two, $21 buys four. Any of those quantities, fit medium mailer, usually less cost than flat rate. USA only.
Making sure contact info's complete, for emails, texts or calls. Recommending a brief text intro, I get a lot of spam.
Funds collected will go toward buying Alliance position. Remainder to project unlike any within hundreds of miles radius, doing things I mention here regularly.
