My attached garage only has 3 lights and 2 outlets, and it's driving me nuts. The lights are on a single 15 amp circuit and the outlets are on a 20 amp circuit. I'm planning on adding a bunch of fluorescent lights onto the existing light circuit and adding as many 120v outlets as I can in parallel on the 20 amp circuit. What I'm missing is a 240v outlet, so I figured I'd pull another wire or two from the house panel and get a couple of 240v outlets in the garage for my compressor and bigger tools.
My question - my basement is largely finished, and the wire run will have to come from the opposite end of the basement. I'd like to limit the amount of damage I have to do to the finished ceiling when pulling the wire. There is a boxed in part of the ceiling that runs perpendicular to the joists from the area of the panel to the other end of the basement. It contains both a supply and return duct for the HVAC. I've found references to code that indicates you can't run wire IN the metal ducts (at least parallel in it vs perpendicular through it), but is there any issue with running it inside the framed in box alongside the ducts? In order to limit the openings I'd have to make in the ceiling for wire hangars, I'd like to run the wire in some sort of conduit, since I assume I would need to use fewer hangars that way. The run in the conduit would probably be around 15 feet or so.
I'll have to pull a permit to do this work, so I'd just like to get my ducks in a row and do it right. There's nothing worse than having to rip things apart for an inspector! Any advice would be welcome.
