"Getting out of the wall" for surface installation
e34 brian
I'm all set to start my surface installation of lights & outlets, tapping into the existing flush-mounted light and plug. My one issue is what exactly code allows when I mount a surface box on top of the existing flush-mounted box.
I know to use a box extender, but here's the rub. The existing boxes are mounted flush with the inside edge of the drywall. I'd like to mount a box extender to the outside edge of the drywall, pull the wires into the new box, and go on with my install. I can't find anything on if it is OK to sandwich drywall between 2 boxes, or if the extension has to have some sort of metal sheath between the 2 boxes to protect the drywall. It seems safe, but I don't know if it's 'proper.'
Any know about this or know which codes I could re-review?
E
e34 brian
Wow, I've been surfing here and reading for 2 days and didn't figure this out myself. THANKS Ace, Sparky, Jason. You answered all 3 of my questions. What needs done, how, and if it's required by code.
Now to go find that square 4" with a cutout for the plastic goof ring. Amazon to the rescue.
Norcal
1st - it violates UL listings and some people are sticklers
2nd - All metal parts need to be bonded to ground and the plastic pieces make it difficult.
How does it violate the UL listing?
A plastic extension is not going to make any difference bonding parts together, the only connection will be the screws between the box & the surface extension.
prostreetamx
Las Vegas
All my boxes are already plastic and if I needed an arc shield they would also be plastic. Have had issues with the metal ones hitting the side screws. If you use a metall 4/0 extension ring and conduit all you need to do is ground that part with a clip or screwed on green tail from your existing ground. The arc shields would be sandwiched between the original box and the new extension since they have a flange that fits around the screws and sits on the wall surface. do not rely on the device screws to provide a reliable ground, even if the original boxes are metal. Even with metal boxes, receptacles still need an attached ground unless they have the extra tang around the screw that provides a ground path. Even then I would use a ground wire on the receptacle. We use those 20a plugs on everything for doing Trade Show electric and bad grounds are a very common issue when the extra tab wears out or the screws loosen up from the constant use and storage of our equipment.
Stuff
I always thought that metal mud rings and extensions were not listed to use with plastic boxes just like MC cable isn't listed. Grounding with a clip makes sense.
E
e34 brian
Why are your boxes installed flush with inside of sheetrock?
I'm not sure. I'd have to ask the contractor that did it in 1978. It may have to do w/ it being a light fixture.
zmaxmotorsports
South of omaha
They make 2 gang fiberglass boxes that are made to have metal plaster rings to make them either 2g or single gang depending on what you need.
CNGsaves
KS and OK
Cut a 6" wide strip out of sheetrock around the shop and "go to town" installing all the electrical improvements that you want/need.
Fishtape the wire up or down from the cutout in the sheetrock for outlet placement. Don't forget outlet up in ceiling for your hanging electrical reel !! ;)
Then patch & re-mud the sheetrock when everything is done.
zmaxmotorsports
South of omaha
:thumbup::thumbup::thumbup::thumbup::thumbup:
E
e34 brian
Yep. Definitely doing the improvements.Personal preference, I'm sick of drywall for this year. Conduit appeals to my inner 10-year old with tinker toys self. Thinking of running another circuit from the breaker box and then wiring 2-gang boxes, 1 gang 15A, 1 gang 20A. But then I start thinking I may want to get into welding and a 50A would be nice. And so it goes.
Look what this forum is doing to me!
E
e34 brian
Can any of you code-savvy folks direct me to the codes that address this? I'd like to read up on this and understand exactly what I need to install. Again, the original builder mounted my electrical box on the inside edge of the drywall and I want to put a box on the outside edge of the drywall.
The extension ring we talked about earlier is a 1-gang size and it seems weird to me that I can run my wires through that and ignore the gaps left outside of the 1-gang extension. (Amazon link). I'm also wondering if I can simply mount that extension ring to the outside edge of the drywall, mount a normal box on top of that and run my wires through the extension ring and into a punchout on the bottom of the new box.
Whatever I end up learning/doing, I'm definitely going to post a step-by-step of the install with pictures. I doubt I'm the only one w/ this problem.
