Dodgepu360
I need the GJ experts to look over my plan to make sure I’m not missing anything. I have an electric pole 85 feet away from my newly built shop. The pole has a meter and a 200 amp panel. The panel has a main breaker and has feed trough lugs at the bottom us the bus bars. If I understand everything correctly, I can connect to the feed trough lugs and run 4/0-4/0-4/0-2/0 aluminum cable underground over to my building. I plan to run it in pvc conduit. At the building I plan to run it up the outside of the wall to an emergency disconnect and then into the wall to the sub panel located immediately behind it. I will drive in 2 8-foot ground rods near where the conduit comes out of the ground.
This is the disconnect I’m thinking of using: https://www.homedepot.com/p/Square-..._-207055267-_-1-_-n/a-_-n/a-_-n/a-_-n/a-_-n/a
This is the panel I will be installing in the shop: https://www.homedepot.com/p/Square-...r-with-Cover-Ground-Bar-QO42L225PGC/320718528 Unless I need a main breaker on this panel?
The existing panel on the pole is a Square D QO so I figured I would stick with that.
What do you think?
What do you think?
