Hi folks,
Long time reader, first time thread poster. I recently moved to a house in western MA with an unifinished 27x40 detached garage. The ceilings are 12'3", 6" floor, 100A service, and lofted storage space above. I'd like to convert this to a place for working on my track car (89 BMW 325), summer car (88 M3) and our daily drivers, as well as other misc projects. This means making it something I can work in year-round on the weekends, and storage for fluids and things that shouldn't freeze.
I travel during the week for work, so realistically the only way to prevent this being a 5 year project is to sub out some of the pieces when it's something I'm not comfortable with (gas lines!) or labor intensive for me to do alone.
I'd welcome any suggestions on what I'm forgetting, especially things that are a PITA to add later, or corrections in what I'm thinking.
1) FLOOR: "paint" the floor. since it's already stained at this point, necessary to grind, right? I think epoxy is plenty for my needs.
2) ELECTRIC: I have quite a few 110 outlets, but would like to wire 220 for a compressor (under stairs), lift (over left rear parking bay), and window a/c. What am I missing? (I don't weld currently, or have immediate plans to learn.)
3) HEAT: I have a 1000gal propane tank in the front yard, about 100yards away (not a straight shot). I also have plastic conduit running from the basement of the house near the furnace & water heater to the garage (assuming I can't run a flex gas line through that?). I'd like to be able to keep it ~40 in the garage in the winter, and just warmer when I'm using it. Thoughts on plumbing off existing tank vs. small secondary tank vs. electric?
4) WALLS/CEILING: In case I ever need to open a wall to change something, am I better off sticking with fiberglass insulation vs. spray foam? And at my size, is there an expected advantage in cost of one vs. the other? Leaning towards dry wall vs. OSB, but could be talked out of it. I'm expecting to keep the upper storage space uninsulated, walling off the stairs with an isulated door (maybe a double door, even if awkward, so I can snake larger items upstairs).
Any input is appreciated!
- Chris
- Chris
