GFCI Circuit Tester Tool
rtz
Oklahoma City
The camera can't "see" the lights. But I have all three lit up and that combo isn't even on the chart. What's that indicate?
R
rtz
Oklahoma City
How can it tell though? Supposed to be 60hz 120V AC output. I don't have a meter on me to see though at the moment.
teamextreme
Lakewood, CO
Same is true of most UPS outputs, those recep testers don't read accurately on them. They often show reversed hot/neutral. We had a customer complain a control panel outlet fed from a UPS was wired backwards because he tested them with one of those testers.
Bert_
NW Iowa
The GFCI testers work on the fact that neutral is always bonded to ground. So you have 120v from hot to neutral and hot to ground, no voltage from neutral to ground.
Those little inverters have 120v but it is something like 60v from hot to ground and 60v from "neutral" to ground.
R
rtz
Oklahoma City
Wasn't home and wasn't going to be home for a bunch of hours. Jammed it in that inverter expecting "normal" results(lights).
nehog
Jaffrey, NH
It is simply telling you both lines are hot with respect to ground. Not surprising with a cheap power inverter either.
