SlappyWhite
In EE we called this ELI the ICE man (as a remembering tool).The primary cause of imbalance between line and neutral (that aren't actual faults) is usually capacitive not magnetic. EMI filters have small line to ground capacitors which is one cause. Most inrush happens on the line and neutral at the same time. A coil doesn't delay current going in one end from when it comes out the other end of it which seems to be what you are saying.
Voltage (E) will lead the current (I) in an inductive (L) circuit. Current will lead the voltage in a capacitive circuit (C).
