Rstark18
I was dry walling a wall in the garage which made me look at the outlets on that wall. both of them are not grounded. I figured the easiest way to deal with this is to replace the old outlets with GFCI.
Picture 1 shows the way it was originally wired.
Picture 2 shows the way I THOUGHT would work (basically replacing the old outlets with the exact same wiring config as the old).
Picture 3 show the final way I wired it.
In picture 2 the GFCI trips as soon as switch A is turned on. I THINK this is because there isn't a neutral on the load side of the outlet. Is that correct? If so what would be the proper way to connect the neutral or is there no proper way?
