Mr onetwo
I am in the midst of changing a bunch of stuff in my shop and it includes a few circuits for equipment that will no longer be considered permanent because I want to feed them with outlets.The goal is to get rid of as much air powered stuff and to make everything as movable as possible.There will be 2 separate 240V 20A single outlets for my compressors. There will be a single 240V 15A outlet for my new overhead hoist mounted centrally feeding a festoon.I want this stuff to be out of the way when not being used. I also will be feeding 3 Hubbell 4-PLEX GFI outlets on separate 120V 20A circuits.Finally I want put an Emporia Smart Plug on the overhead propane tube heater so I can monitor it's power consumption with my Vue Gen2 system. I will have to convert this to a 120V 15A single outlet. Locally we are adopting the 2020 NEC next week. My question is whether I can use regular breakers or will I be forced to use GFI breakers on the 3 equipment locations to meet code. Because the 4-plex outlets are GFI already do I use a regular breaker or do I have to use an arc fault breaker.Everything will be in EMT and the panel is a 150A Homeline PON 30/60 main breaker.Thanks
