Hey guys. I am going to call my electrition on monday but this is gonna drive me nuts all weekend. I am finishing off my garage. My electricion let me run all the wires and outlet boxes. He came in after i was done and looked it all over and said it looked good. Had an inspection and all was well. Then i put up my insulation and sheetrock (have not mudded or taped yet). He came back, installed all the GFI's and the breakers in the panel, and let me install the rest of the "regular" outlets. When I would finnish a row of outlets, I fliped the breaker and reset the GFI and made sure all the outlets worked, and they did. Now tonight I finnished my LAST row of outlets, fliped the breaker, went to reset the GFI, and it wouldnt reset! Shut off the breaker, compleatly removed the first outlet after the GFI, turned on the breaker and went to reset the GFI. SILL wouldnt reset!!!! Now I am totaly confused. I thought if there was any trouble AFTER the GFI that it was suposed to trip. And I assumed that since I was the one who wired in those outlets, that I probably messed something up. That's why I tryied to eliminate everything AFTER the GFI. Will a GFI trip if there is a problem BEFORE it? The only thing before the GFI is the wire leading to the panel to the breaker. Is it posible that my electrition could have wired the GFI wrong to cause this? Please shed some light on this so I can sleep at night. Thanks!!
Took it back, got a new one, and it works to this day.
