gidday
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
Welcome to the GJ.
May I suggest you update your profile with your location (other than at home) in your profile as in future you may find that helps. Specially given this is a very global forum. Often you will find subjects may get different answers depending on locations and regulations. The location you have listed is not going to help you in future.
If you are interested we have an Aussie Kiwi social group section as part of the forum.
A few Aussies around here. Not many Kiwis. Thankfully you both speak (almost) the same language !
I learned a new Aussie term the other day. An adjustable wrench (spanner for you English blokes), which is commonly call a Cresent wrench (after one of the major manufacturers) is sometime also called a "farmer fitsall" (for obvious reasons).
Down under it is called a "nut fucker" ! Probably more accurate than "farmer fitsall" !
