Bagherra
Saw this on Amazon today? What's ya'lls take on this?
Even cheaper....... I use the lug wrench that came with the vehicle and a gas pipe as the force multiplier.I think it is a gimmick that's more heavy than what it is worth. Probably even end up scratching some nice rims with that awkward thing, and I expect the gears are all dry and crunchy inside.
Extendable breaker bar is cheaper, takes less space, is lighter, and will not fail. Or if going very cheap, a short breaker bar and a cheater pipe. For normal cars it should really only be 80-90 ft lb, and most people can easily do that with a regular 10" lever (standard 1/2" ratchet). At same force on a 20" breaker bar, you're looking at near 200 ft lb...
Heavy equipment is a different matter. But then you get professional torque multipliers for that. Those work great but are very expensive...
