Give this one a try! Whatzit?
twertsy
Reedville, VA
Snagged this off ebay because I had never seen the Bonney name with an "S" on the end!? Now, I have only hints at what it is. Any guesses? (and no, I don't know).
A couple things to point out: 1. The top is made for a brace; 2. Notice the amount the blade would penetrate the work piece is very different for each hole.
KRB52
I was thinking it could be for cutting threads in wooden dowels, the way the blade is off-set. Doweling cutter works for me, too.
Hawk
Kannapolis, NC
The top is made to put in a shoulder brace hand drill. A shaft of wood just a little larger than the finished dowel is placed in the selected hole size. The bottom of each hole should be just a little larger than where the blade is set. Then using the shoulder brace which will turn the unit to shave down the dowel into a cylinder, the size depending on which size you choose. On that unit it should go up to an inch. This was normally used to inset rungs on a chair.
