z28snksknr
I'm trying to come up with a design to mount my struts to my frame. The top plate was easy enough to figure out, but i wanted to run my (4th) design by you guys for some input. Here's some pics of what I'm trying to mount:
I'm going to weld DOM tubing around the perimeter of the top plate to make it stronger- here's my best attempt at representing that with cardboard and tape:
I'll add two vertical supports using DOM tubing, attached to an L-shaped plate that will attach to the frame to spread the load out. I may make that plate 2 smaller pieces since the 14" plate is a bit overkill i think:
And side gussets that will warp around to the front of the top plate (its hard to tell from the pic, but there is only a 3-4" space between where the two gussets meet the top plate - almost all the way around it.
So, it is strong enough? Is there a simpler, or more aesthetically pleasing scheme? I'll need to shorten this mount since the actual ride height will compress the struts ~3", but I have no way of doing that, so i'll have to try it, check ride height, and keep cutting until i get the stance i want.
Thanks in advance!!
Thanks in advance!!
I understand that approach and will definately incorporate your comments. I have some limitations on how much less I can scallop the sides because of the control arm swing clearance, but I may cut some small holes out. Thanks for the input
